just slammed my srt6 to the ground with bags!
Re: just slammed my srt6 to the ground with bags!
dude your the man ...as im looking at it. it seems that theres a plate welded on the bottom and the top for mounts ...wonder if theres a bolton direction to go with this ... whats the low down on the setup i know i ask to many ?s but im very interested in this type of setup seeing ill have this car for awhile
eric
eric
eric
eric
in the front, there is a bolt in upper bracket "cup" with a thick cap that the bolt goes through along with the airline. you will see that the upper bag plate has a flat spot for shock clearance. on the lower front control arm, a plate is welded in place. its very simple.
the rear is even more simple. the upper cup just slides into the coil pocket. dont worry, it stays there. the lower bracket is just another plate welded to the control arm.
before i wanted to put these brackets on the market, i wanted to make sure that everything was right. after 4 years and 47,000 miles there is not 1 thing i would change about the design. one thing is, you have to run re5 slam specialties bags. they are the perfect size for bagging these cars.
yeah you guys build some quality stuff there...so your thinink about putting the brackets on the market thats cool...i was just thinkiing of a bolt on style way for the lower braket incase i have to put it back to stock you know...mabye on the botom contol arm dril some holes in th plate or put a plate on the bottom of the control arm and kina sandwich it together...thats how the bags on my chevelle worked if i remeber correct
eric
eric
eric
eric
it wouldnt take no time to remove the lower brackets with a cut off disk if you were to put it back to stock.
Originally Posted by sonoronos
Beautiful fabwork!
Have you ever thought about fabbing some custom control arms that don't put the ball joints at such an extreme angle?
does anyone make aftermarket tubular arms for the crossfires right now?
rogerlemoine
10-26-2015 12:02 AM
2005 Ragtop
10-03-2015 03:01 PM
