It finally happened.
Today, the TPMS died. After 12 years, that was it. No warning, LOL, just suddenly the light came on. Has not been on for the almost 7 years I have owned the car, but today, it came on and stayed on. Tire pressure normal.
I am not going to pour money into this thing right now fighting the nightmare known as a Crossfire TPMS system. Not worth it. I disconnected the #2 wire behind the dome light and moved it to #6 in the connector. Did not want to have to do it, but do it I must. I will check tire pressure much more often now and live with the fact Butch did a half assed fix to his car.
I will be fine in the morning.
Re: It finally happened.
Never mind , i have this tpms and it works well plus its got a usb charge socket .
TPMS Tire Pressure Monitor System Auto Car Cigarette Lighter +4 External Sensors | eBay
That is exactly what I will get if they give me any grief during my next state vehicle inspection. They are super strict up here now with a computerized system. Not sure if they will pick up on the fact the TPMS light does not now come on with the rest of the idiot lights when the key is turned on.
I can live without TPMS on any of my cars. That is what they make good tire pressure gauges for, IMHO. All it has done is make people lazy and do what they should do, check the tires and the fluids, often.
[QUOTE=daveesrt6;888830]Never mind , i have this tpms and it works well plus its got a usb charge socket .
TPMS Tire Pressure Monitor System Auto Car Cigarette Lighter +4 External Sensors | eBay[/QUOTE
$42US?
Damn, how times have changed!
$42US?
I couldn't Agee more. In the process of making things "easier", I believe companies have made people lazier. Checking your oil and tier pressure, as well as checking the cooling system and brake fluids every couple of weeks keeps maintenance in mind and offers valuable information about the operating health of your car.
I have the kit mentioned in post #2. It works but the transmit units that go on the wheels are larger than a valve stem cap plus you need to have the tires rebalanced with them attached. I took them off the next day. If anyone is interested I'll send the kit to you for $35. They work but I decided to replace my TPMS instead.
TPMS Tire Pressure Monitor System Auto Car Cigarette Lighter +4 External Sensors eBay
I like it alot better since I can see what pressure is in each tire.
I have the kit mentioned in post #2. It works but the transmit units that go on the wheels are marger than a valve stem cap plus you need to have the tires rebalanced with them attached. I took them off the next day. If anyone is interested I'll send the kit to you for $35. They work but I decided to replace my TPMS instead.
?? I have the kit in post 2 , the valve caps did not affect the balance of my brand new wheels at all , dint have to rebalance, smooth as silk.
temps /pressures/ low pressure alarms/voltage and a usb charger all in one small unit.
works for me !
works for me !
Yes, Direct from China is hard/ impossible to beat.
It is a worry .
also, i just came back from a drive and i now think my ride is not as "smooth as silk" as i said afterall !
Thanks, ignorance was bliss . So.. I weighed one of the pregnant valve caps :8.61grams !! now i have to get the wheels rebalanced haha
It is a worry .
4 Internal Sensors OEM TPMS Car Tire Pressure Alarm Monitor System Android IOS | eBay
Internal sensors. $29?
It is a worry .
It is a worry .
WOW... .3oz isn't much but I guess any difference is reason to rebalance? BTW, am curious why you have such a small scale, mine weighs in the 1-300LB range (and I am NOT going to tell you where I land on the scale!).
I went for a drive with the tpms valve caps removed today and yes, it is smooth without them on , but i have them so i will get some of those wheel weights and try sticking one of those on the inside rim myself instead of paying the tire shop to do it.
Also, i measured them with the kitchen scales,not the bathroom one :-)
Ya, its a standard of wheel weights (clip on and stickies). BTW, are they in metric weight in other countries? I was commenting on the .3 oz of the cap and the observation .3 oz causing vibrations.
Are they metric in other countries? Surely you jest.
