HELP!!! BAS/ESP light on
Old 01-05-2016 | 11:16 PM
Alfred107's Avatar
Default HELP!!! BAS/ESP light on
The other day I hit a small curb on the driver side going about 25mph. Car still rides fine no shakes or visual damage. Two day after that the BAS/ESP light came on and wont go off. I did the rest, turning the steering wheel and all. It goes off for a second but comes back on. Has anyone else had this problem. Please let me know if you have. Thank you
Old 01-06-2016 | 12:42 AM
Default Re: HELP!!! BAS/ESP light on
you might have knocked off the alignment of the sensor, , look at both behind front wheels and make sure the ,,,black line goes to the sensor the same way on both sides. , jim
Old 01-06-2016 | 11:14 AM
The steering angle sensor is in the steering column and that is what is realigned when you do the steering wheel stop to stop procedure.
I think you are referring to the speed sensors and they are on the inside of the wheel so they are pretty well protected.
As the light on problem occurred a day or so after the bump I'd guess that the light on situation is not connected to the bump.
SAS OPERATION
The steering angle sensor is a digital sensor with nine light-emitting diodes. The diodes within the sensor are used
to detect rotation and position of the steering wheel. This sensor can detect the steering wheel rotation and position
up to 720° of rotation. The steering angle sensor has continous battery voltage supplied by fuse 14 in the underhood
accessory fuse block.
Checking fuse #14 mentioned above would be a good first step, although I doubt that is the problem. Possibly a brake switch malfunction?
Old 01-06-2016 | 11:19 AM
Alfred107's Avatar
Thanks for your input I'll check fuse 14 and the sensor wire
davidf30
02-19-2020 11:00 PM
Matlock
01-13-2016 09:18 PM
Valk
12-22-2015 06:18 PM
jwhdfw
12-21-2015 10:15 AM
xfirejeezy
12-14-2015 08:26 PM
