Help with brake kit
Old 12-07-2013 | 04:47 AM
crossfire1989's Avatar
Default Help with brake kit
Hey, I recently purchased a 4 pot STARTECH(Brabus) brake kit on the forum. From what I understand it is an upgrade from the SRT6 brakes or Mercedes brakes. I have an NA Crossfire. I was told that it is a plug and play kit. However, does anyone know if I will need additional bolts, spacers, nuts, etc for the install? Thank you for your time and information.
-William
Old 12-07-2013 | 06:27 AM
bluecoupe's Avatar
Default Re: Help with brake kit
Direct bolt on, no additional hardware required. I did use a longer brake line and with the 330 mm rotors, stock wheels will require spacers.
smfrycruzr
07-17-2023 05:33 PM
RamblinShamblin
08-12-2017 10:55 PM
UNDER PSI
11-01-2015 09:39 PM
2005 Ragtop
10-03-2015 03:01 PM
Big Daddy
09-10-2015 10:21 PM
Quick Reply: Help with brake kit
