I want 18" Tires w/identical tires on all Four wheels
Dear Friends:
I own a stock 2006 Crossfire Coupe with the original Front 18"/Rear 19" wheel set-up with stock Continental tires. I bought the car used in July with only 12,800 miles on it. Smelled new and drove the same.
Many of you probably have discussed this question in detail...
What should I use in terms of tires, etc. to have all four wheels running the same size 18" tires/wheels? I am working off the assumption that the rear can accept the stock Crossfire 18" wheels because the bolt pattern is the same for front and rear.
What does it take, and what do I need to know?
Thanks,
Scott
Toccoa, Georgia
Thanks,
Scott
Toccoa, Georgia
Re: I want 18" Tires w/identical tires on all Four wheels
The bolt pattern is the same but the offset is different so you might need some spacers to get it to "look" right. Also, the smaller diameter rim will need to be compensated for with a taller sidewall tire to get close to the same circumference of the 19" OEM set up to keep the speedometer reading correctly.
Try searching for " 18" Wheel " in the Google Custom search bar at the top of the page and see what you come up with - a lot of comments and suggestions on those threads.
RL
RL
Also, I have a pair of 18" wheels with tires, as well as a pair of 19".
Tires ain't much to talk about, all the wheels are 7 spokers ( standard NA )
If you want 'em, you'll have to come get 'em, I have no way to ship 'em.
If interested, we can haggle a price.
RL
RL
Dear Friends:
Thanks,
Scott
Toccoa, Georgia
Thanks,
Scott
Toccoa, Georgia
Try this.
I use 18's on all four corners for the race track. If you insist on having the same size on all four corners you can fit a 255/35/18 on all 4 corners. If lowered you'll need to roll the front fenders. If at stock height they will fit with a 30 offset on the front. Let's just say to be able to rotate the 4 tires to all four corners for what ever reason, you'll have to buy custom wheels. I don't know if it's worth it or not.
Les
Les
Dear Friends:
Thanks,
Scott
Toccoa, Georgia
Thanks,
Scott
Toccoa, Georgia
As Ala_xfire said, you are welcome to join us for the fall Dragon event - and if you attend, you can discuss this in person with those who know. I'd stick with the factory set up all the way around - this car was DESIGNED to run with 18/19's and it does so very well - I think you will be sorry for trying to get away with what is quite a change.
Please read these threads:
https://www.crossfireforum.org/forum...r-4-5-6-a.html (Well, maybe just the first three posts....)
https://www.crossfireforum.org/forum...y-atlanta.html
You have wandered into a wonderful community of friends here - and everything you need or want to know about your car is here as well.
Welcome to the fun!
We could meet him (her?) at GA9 and US129 at 1:30
Well ..... it was a tongue in cheek response. "What's a couple of inches anyway".
I see I am going to have to spell out JOKE COMING.
For my friend in Lineville, AL:
My Mapquest tells me that you are not really that far from me, about 193 miles. I am seeing a range of prices on Ebay, but they all naturally include shipping. Should we talk about price on the phone or via e-mail?
Scott
Toccoa, Georgia
Scott
Toccoa, Georgia
Last edited by Voyager1988; 10-03-2013 at 08:26 PM. Reason: Should have added an addressee
Additional Questions...
1. Has anyone tried a 225/45/18 on the FRONT? If so, did it clear the fenders, etc.?
2. Several in this thread have remarked that a narrower(e.g. 225 width) tire would look funny mounted on the back wheels. Anyone have a photo to post of how that looks without spacers?
My own calculations tell me that a 225/45/18 on the back will not change the speedo reading much at all.
Scott
Scott
Scott
Scott
Good Question, Jim!
A few statements are in order...
1. Despite my ownership of a Crossfire, I am actually a very conventional person.
2. My Crossfire, under my ownership, will never enter competition/race. It is a daily driver.
3. For people like me, who enjoy both the looks and handling of the car, but don't look to increase its performance, we think of other things.
4. I can't think of why I would need 255 width tires on such a small, short car for my driving.
5. I think that the inability to rotate tires is an inconvenience.
6. I am "testing the envelope" with such questions.
7. My rear tires are at the wear indicators at just over 15,000 miles and 7 years(got it on a trade), so IF I make any switches on wheels/tires, now is a good time to do it, and not later.
Thanks for your advice, and for asking why.
Question: What is the impact of NOT using an offset on 18" tires?
Scott
Scott
Last edited by Voyager1988; 10-05-2013 at 09:51 PM. Reason: Added a question at the end.
Re: Good Question, Jim!
Scott
Scott
I just assumed you'd want to go wide. If you want to be able to rotate 4 ways and are a hyper miler it can be figured out. You can put 18x8 on all four corners with a 32 offset and it should work. I doubt the cost of the rims will equal any savings from being able to rotate the tires.
Les
Les
I just went through this with my new long distance tourer. Came with 18x8.5 front with 235x50R18s and 18x9 rear with 265x45R18 rear. Since not a track car I went to 17x8s on all four with 235x60R17s all around. Did require spacers/tuner lug nuts with extended shanks to clear the calipers. Drives just fine and has a noticeably smoother ride while tires are about a Benjamin less each than the 265s.
As long as nothing rubs and you do not get any bump steer, there is no reason not to.
Living in Florida where we get intense rainstorms I value wet traction and lack of hydroplaning very highly. Mercedes has 17s that will fit nicely. Make sure they are for 12x1.5mm bolts and not 14s.
ps whole thing started because the almost new Michelin Pilot MXM4s that were on it were terrible in the wet (first street Michelins I've seen that were bad in the rain). Now have BFG T/As that are excellent.
