Front Suspension noise
Old 03-15-2010 | 02:03 PM
clem05XF's Avatar
Unhappy Front Suspension noise
I have been going crazy over noise from the front suspension. I have inspected, torqued or adjusted the following:
- shock absorber mountings and bushings (bilstein hd w/full bump stop)
- control arm bushing (in very good condition)
- ball joints (cannot find any play)
- tie rod ends (no play here either)
- sway bar bushings (in very good condition)
- front wheel bearings (tightened a little - as much as i dare)
- torqued the pinch bolt at the bottom of the steering column near the steering box
The noise is caused by a small sharp bump and normally at relatively slow speeds (50mph or less). It also comes from either side of the car. (05 XF roadster). Otherwise the suspension is compliant and rides very well considering it is a sports car.
I have run out of things to check and would appreciate any suggestions you may have.
Old 03-15-2010 | 06:45 PM
apkano's Avatar
Life is random...so am I.
Default Re: Front Suspension noise
The type of noise might be helpful here.
Is it a chirping, squeaking, clunking, thud?
I had a squeaking sound go away when I replaced the steering stabilizer.
Old 03-15-2010 | 08:39 PM
clem05XF's Avatar
The noise is more of a clunk. No squeaking or rattling.
Thanks for your consideration.
Old 04-08-2010 | 09:45 PM
cought in crossfire's Avatar
Cool Re: Front Suspension noise
Mine is more of a vibration . I have had the balance of the tires done alot re mounted the tires back on , different types of tires . This one kind of has me out there, well maybe some one has an idea . Yes the Roadster is in very nice ride but not smooth
IGot2P
10-24-2023 03:56 AM
massanu
18
11-23-2015 09:52 AM
velociabstract
28
10-28-2015 01:46 PM
maxcichon
09-04-2015 01:50 PM
velociabstract
08-07-2015 02:30 PM
