Here is the wheel deal
Old 08-11-2009 | 07:38 PM
waldig's Avatar
Talking Here is the wheel deal
This is the wheel deal for you gear heads that have swapped wheels, added spacers and had to shorten your bolts. The bolts have a way of sticking into the wheel hub too far and hitting the rear brake springs.
Cutting the studs shorter is not as easy as throwing them on a grinder and shortening the stud length. The first thread is very likely not true and has a lip that will cause thread deformation over time as the wheel is mounted and unmounted.
Please let me show you a practice that I use to cut them shorter and have a good bolt when done. Get a 12 x 1.5mm Die ( die is the part that makes male threads, as compared to a tap that makes female threads). You have but to only screw the die on to the uncut bolt before you grind off the end.
When you grind the bolt the die in un screwed from the bolt clearing the threads after the grinding process. Its real simple and easier than forcing the bolt into the wheel hub to form the first thread, Getting it a little wrong is a bad thing and boogers up the threads. Remember 12 x 1.5 mm die, Tap it you wanna true the hub threads, photo shown here.
My rear threads are shorter so I color coded them to keep them straight, front versus rear wheels.
Another hint is to have a small magnet handy when you swap wheels. I have gotten tired of chasing the bolt after it is loose and in the wheel cavity, magnet pulls it right out.
Another trick is the sanding of the 17mm socket so it is baby butt smooth; to protect the wheel’s finish. I have spoken of this previously but it is cheap and till you see it you don’t know how good it really is. Chuck the socket into your impact gun and hold a sandpaper sheet in your GLOVED hand. As you run the wrench spinning the socket the front edge is smoothed and polished if you use fine paper to finish up.
When you do the wheel change and bump the wheel the socket does not take out a divot on the finish, sweet. Photo shown to give you an idea of the look, like fine silver and sooo smooth. Did I say easy??
Waiting fer the weekend WOODY
Old 08-11-2009 | 08:27 PM
dwightdmagee's Avatar
Banned
Default Re: Here is the wheel deal
Boy, waldig, that is the wheel deal. Thanks.
Administrator: recommend this be sticky under Wheels, Brakes, Tires and Suspension.
Any seconds?
Old 08-11-2009 | 09:00 PM
MikeR's Avatar
Woody,
Why dont you just chuck it up in the lathe and turn it down? Dont be so lazy.....
Excellent tip for shortening bolts. The masses thank you.
Old 08-12-2009 | 07:55 AM
waldig's Avatar
Talking Re: Here is the wheel deal
Being that Iam in the last quarter of life and a C and open heart surgery survivor I'd kill for a lathe now. My 6 car and 2 car garages are neatly filledl though so your safe for now Mike.
My lathe is a black n decker 3/8s drill Chucked in a bench vise thank you.
It'll do for most small things.
Woody looking for another tool toy. Yeah
iPhone.
Old 08-12-2009 | 10:29 AM
or you can get the correct size lug bolt from me at my cost. and not have to cut it at all jim
https://www.crossfireforum.org/forum...ight=lug+bolts
Old 08-12-2009 | 11:50 AM
waldig's Avatar
JIM< Call me asap I need to get 20 bolts at 35mm shank length, ABOUT 58mm overall.
Shank 35 MM. Woody 703-929-4100
Old 08-12-2009 | 08:30 PM
Done........
Old 08-12-2009 | 09:57 PM
Really? I would not have thought that would be so effective.
Old 08-12-2009 | 11:15 PM
CALL911's Avatar
Or do a stud conversion! It's also easier to mount the wheels. I don't understand why mercedes still uses bolts instead of studs.
Old 05-17-2010 | 07:51 AM
TerryR's Avatar
The age old way to ensure end threads do not create any problems when reducing length, is to run a normal nut on first, few people have a die available, but most can obtain a nut. I have done this for many years.
Old 02-17-2012 | 04:18 AM
sylviaF's Avatar
Thanks guys for all your post, it really helps.
TerryR
12-13-2019 03:27 PM
Darryl Camisa
10-07-2015 07:10 AM
10-01-2015 01:42 AM
Mackel
09-29-2015 02:41 PM
ozkancab
09-25-2015 10:55 AM
Quick Reply: Here is the wheel deal
