TPMS new tires
Old 06-10-2008 | 05:11 AM
sweldon2's Avatar
Default TPMS new tires
Hello all. Im a noob here with the Crossfire and need to do a tirechange. I have taken over the maintenance on my GFs 04 Coupe and Im putting new tires on it for her. I putting Kumho SPTs on it and I have never had to deal with a TPMS monitoring system. Is there anything i will have to do different? I wish i could turn the TPMS off because i would rather check my tires like we used to do in the olden days... Thanks all
Old 06-10-2008 | 05:18 AM
GatorLCA's Avatar
Default Re: TPMS new tires
Not that I know of. They are put on the ends of the valve stems, the place where you get them changed out will know there are TPMS monitors on there.
You can take them off but you'll have that pesky "low pressure" light on on your dash
Old 06-10-2008 | 05:21 AM
maxcichon's Avatar
Question Re: TPMS new tires
That's a really good question!
Last night I put new rims and tires on my roadster, but I bought 4 used TPMS sensors from LKQ on ebay and installed them.
60 miles and no dummy light. When does anyone think they would have to be "reset" at the dealer, or are they "plug-n-play"?
P.S. Falken 452's 275/30-20 rear and 235/35-19 front.
Old 06-10-2008 | 09:48 AM
sweldon2's Avatar
i dont really care about the light. Its nothing a little black electrical tape cant handle..... I just dont want it setting off any CEL's, if thats possible. Thanks for the input!!
Old 06-10-2008 | 10:38 AM
MikeR's Avatar
Sweldon, if your just changing tires there should be no impact. Put the new tires on and go. I think you will like the Kumho SPT's. I have them on the rear of my Aero (came that way used) and I am pretty happy with them.
MikeR
Old 06-10-2008 | 10:41 AM
MikeR's Avatar
Also, you should still check your tires regularly to be sure they are properly inflated. The TPMS will only come on when one(or more) tires drops more than 10%(?). Not sure on the percentage drop. So keep that tire pressure gauge in the car.
MikeR
Old 06-10-2008 | 11:49 AM
sweldon2's Avatar
cool thanks guys. this car is only driven 1K a year if that and the michelin pilot sports on them and they only lasted 10K. I just hate those TPMS sensors, i would fill the tires correctly and than 10 miles down the road they would come back on.....
Old 06-10-2008 | 04:23 PM
MikeR's Avatar
Are you saying that you are loosing pressure? Go back to the shop that put your new tires on and have them find the leak and fix it! You could have a bad sensor if the air in all tires is within a pound or two of the same (and you dont have a leak).
MikeR
Old 06-10-2008 | 08:04 PM
Kurts's Avatar
Welcome, Sweldon!
Try the magnet trick!
Pass a donut-shaped magnet over each valve stem & voila', end of sensor issue!
There have been several other recent threads about this. Do a search for "tire sensors" & you'll see a few references to your issue!
TerryR
12-13-2019 04:27 PM
Mackel
09-29-2015 03:41 PM
SRT6_Roadster
09-24-2015 05:40 AM
stelrz1
09-21-2015 12:18 PM
caseydeankopp
09-13-2015 08:25 PM
