Replace your Steering Stabilizer, you'll be surprised.
Re: Replace your Steering Stabilizer, you'll be surprised.
I'm wondering why everyone is ordering from Joeltc...i just got the OEM part from Autohaus for $35.89 shipped. Also i could have gotten free shipping if i ordered 2, which would have been ~$50 for two stabilizers. Not sure why you would go aftermarket, especially considering the people that have said the OEM parts are far more resilient. Just figured i'd chime in...
Bought the Stabilius (approx $26) from AutohausAZ a few weeks ago. Added cabin air and engine air filters for our other vehicles to get over $50 for the free shipping deal. The damper must have expanded a little and/or was handled roughly during shipping because it poked a hole in the corner of its shipping container and was released back into the wild. All I got was an empty box. Fortunately, the folks at AutohauzAZ are quite reputable and they sent out another one which arrived safely.
Installation of the new damper suggests that my original was still good. I didn't notice any change. I'll keep the old one as a future replacement. Then again I only have 21K miles and evenly wearing original tires on it - DOB September 2003. I think I might even spring for new tires next summer.
Why does AutohausAZ not even list the steering damper under Crossfires? I found the part under the '04 SLK 320, but why isn't it listed both places? I have a fear of being crushed by my car so I've been trying to find a shop, but nobody can even find the part.
Does anyone have the time to give me a pep talk about how my car won't fall off the jacks and kill me if I do it the right way?
First try to be on level ground and put a piece of wood or block like a 2x4 in front of and behind the back tires to lock the car in place & then just jack up your car one side at a time using the proper jack points provided just under the rocker panel you will see a couple of pads to use to jack up. Put in a jack post on a nice solid part of the frame and let the jack down on it and then repeat for the other side. Jus make sure your Jack posts are on a solid surface and if you are on an a driveway you care about or asphalt throw a piece of plywood under the jack post so it doesn't sink or make marks in your driveway.
You will quickly be able to see the 2 bolts you need to remove to get at the stabilizer and as per previous posts in this thread you need to turn the steering wheel a bit to access teh one bolt.
When I did mine it took me less than 20 Min. from start to finish.
Read the previous posts and there is lots of info on where to find the parts and part numbers etc. & yes it's best to shop for the part as a 2004 SLK part as it is lss cost and easier to find.
There's your Pep talk - good luck.
Steve
on
Cheapest price I've seen for a Steering Stabilizer
Just seen today on FCPEuro...
Meyle 1244630432A
Mercedes Steering Damper - Meyle 1244630432A | FCP Euro
MSRP $45.25 (You save $27.15)
Our Price: $18.10
They also have the Stabilus 1244630432
Mercedes Steering Damper - Stabilus 1244630432 | FCP Euro
Our Price: $32.44
This item qualifies for Free Standard Shipping With an order size of $25. On all domestic orders.
As inexpensive is the Meyle, you could actually replace it at every oil change!!!
Meyle 1244630432A
Our Price: $18.10
Our Price: $32.44
I was reading the tire discussions on here and saw a few people talking about how the rear end felt like it was going to "break loose." I have 112k on my car, about 30k on current tires, and am starting to sense that same thing. It's been a bumpier ride lately, not just steering wheel vibration. The car feels nervous, as others have described. Does the damper help out with that? Or am I better off doing a bit of an overhaul with new shocks and tires in addition to the damper?
Just replaced my steering stabilizer at 50,000 miles. Very easy fix, it took longer to jack up the car than it did to replace the part. Took it down the road for a test drive, and it drove like new money. Just got my crossfire a month ago, and all I can say, this is a great car. Thanks to all the knowledge on the forums it will allow me to fix lots of problems very easily.
DJ
Those are $19 and require about 3 minutes to replace ....
( http://www.joetlc.com/steering-dampn...opmlfs5e1ivg82 )
All you need to do is jack the car up on one side, don't even have to remove the belly pan
2 bolts, bada-bing, bada-boom..
wowzer!!!!
When I first read this thread I asked my wife if her car was steering a little strange. She said it would jump or move for no reason. I said OK, I will try something. Ordered the new one got the ratchet and wrench out and in no time she was test driving and said it was so much tighter, felt much better to drive. Hers had maybe 22K on it, we hadn't owned it very long. This is an easy R&R and for me to say that it really is. jack it up a little turn the tires and do it. Instant and cheap improvement. Wonder how long the replacement part will last? Probably not very long since there seems to be a million of them on the aftermarket. Try it you may like it. Don't forget your jack stands. :-)
did you touch the ground with both hands or just hold your ankles ?
( Steering Dampner Mercedes e 320 400 420 500 e 129 210 - JoeTLC )
