Line lock
Old 10-05-2015 | 10:49 PM
Ian69's Avatar
Default Line lock
Has anyone ever fitted a line lock/anti roll to there Crossfire
If so what kit did you use and how was it wired and plumbed in on the brake circuit?
Did you have to modify the abs?
Old 10-06-2015 | 07:17 AM
ImportLabSRT's Avatar
Default Re: Line lock
You will need 2 solenoids, 1 for each front wheel. No modifications to the ABS is needed. I remove the BAS/ESP fuses when I am at the track so I can do a proper burnout without the ABS engaging.
You will need to find the correct brake line adapters which can be expensive because they are an uncommon size. As for wiring, I have mine wired to a momentary switch on the center console.
Old 01-02-2016 | 10:30 AM
Ian69's Avatar
Where is the best place to get the two solenoid a from,or is it a case of ebay?
Rooster98
12-24-2015 11:59 AM
spoiler
08-30-2015 04:17 PM
Blackktieguy
08-21-2015 02:05 PM
pioneer4x4
07-27-2015 03:04 PM
Rooster98
07-21-2015 01:39 PM
Quick Reply: Line lock
