Tips on how to install your H&R wheel spacers
Old 05-28-2005 | 12:24 AM
Cyril Baldwin's Avatar
Default Tips on how to install your H&R wheel spacers
Here's a great site on how to install a wheel spacer.
http://home.insightbb.com/~davidwhon...cer/spacer.htm
Old 07-04-2005 | 01:37 AM
Default Re: Tips on how to install your H&R wheel spacers
Here's a more Crossfire specific installation of H&R 10mm F and 12mm R wheel spacers
1. Before installing spacers, remove all corrosion on the axle-stub and contact surface.
2 Check that the spacer fits flush against the wheel hub.
3. Replace STOCK bolts with longer H&R wheel bolts.
4. Its easier to mount the wheel spacer first on the wheel / rim hub and push it in until it fits flush to the hub. ( Photo no. 2 )
5. Install the wheel and torque the bolts at 81 ft. lbs.
MAYAman (04-23-2022)
Old 07-04-2005 | 07:14 AM
Core's Avatar
nice. thanks for the tutorial...but i don't get how the spacers are attached with our cars since we don't have studs the way the maxima has studs on the inside of the rotor.
Old 07-04-2005 | 09:44 AM
andrew's Avatar
-C-I-C-C-I Associate Member
the spacer at the inner hub area, press fits into the rim hub...there is an interlocking lip on the spacer. they together very tightly.
Old 07-04-2005 | 11:34 AM
Dan Root's Avatar
Banned
Just curious, does the spacer help LESSEN the negative Camber? In front and rear?
Old 07-04-2005 | 08:13 PM
chxf's Avatar
Cyril. Thanks for this beautiful and interesting explanation.
Old 07-04-2005 | 08:40 PM
I think the spacers just reduce the rubbing in the inner part of the tires. However, there are some adjustments in our driving skills that needs to be concerned of, which is to really slow down in the humps and dips most especially when turning.
maxcichon
05-14-2019 08:30 PM
Roty135
17
10-11-2018 11:11 AM
MAXIMUM
08-05-2015 12:04 AM
3spencer3
07-24-2015 02:08 PM
Buchacho
07-09-2015 05:13 PM
Quick Reply: Tips on how to install your H&R wheel spacers
