Obsolete: Skreem and Antenna $229.25 now available at Needswings
Great news!
SKREEM and Antenna Ring just listed less than 2 weeks ago at Needswings $229.25. According to Rob its Plug & Play. Programing already done for your car, just send Rob all the info at time of order and when you receive it just plug it in and off you go. No more needing to go find a dealership that will charge you to do the programing
"Is your car now starting for 1 second and then turning off? Is the alarm going off? Are you throwing a check engine light for the SKREEM? This could be due to a SKREEM control module going bad and causing issues communicating with your key(s). The SKREEM and Antenna ring combo are located behind the instrument cluster. We can order you another specific to your VIN. These usually take 3-5 days to get in before we can ship them.
In order to process the order we will need a copy of the current vehicle registration and a copy of the owner's drivers license either mailed or emailed to us at sales@needswings.com
Chrysler also asks for the vehicle mileage, so please include that when placing the order, it does not need to be exact.
This is a VIN coded part and is not returnable, please confirm this is your issue before ordering."
NeedsWings Performance Products. SKREEM and Antenna Ring
Re: Skreem and Antenna $229.25 now available at Needswings
thank you, i had an incorrectly named link earlier, i corrected it this morning, the new correct link is
Big Daddy
05-12-2019 09:19 AM
Big Daddy
28
07-13-2018 02:09 PM
