Sticky ignition
  #41 (permalink)
Old 02-04-2017 | 08:28 PM
Whitcat9's Avatar
Default Re: Sticky ignition
My thoughts exactly!!
  #42 (permalink)
Old 02-04-2017 | 08:31 PM
Whitcat9's Avatar
I have no machanical experience. I'm doing the best I can in explaining the situation.
  #43 (permalink)
Old 02-04-2017 | 08:36 PM
Well as we say around here, "Bless yo heart".
If you can start it as you say, get in it with all your parts and head west about 100 miles and I'll be glad to put it back proper.
I can do fiddly mechanical things.
  #44 (permalink)
Old 02-04-2017 | 09:19 PM
Add photos to help explain the problem, it helps a lot.
  #45 (permalink)
Old 02-05-2017 | 02:11 AM
Whitcat9's Avatar
"PIZZAGUY" - I live in tucker, Georgia. Do you know of any reputable auto garage that you would recommend ? It sure would be helpful. Thanks
  #46 (permalink)
Old 02-05-2017 | 04:21 AM
Well, since you chose to completely ignore my post offering to help, I will henceforth ignore this thread.
  #47 (permalink)
Old 02-05-2017 | 10:07 AM
Whitcat9's Avatar
I can't drive 100 miles to get car fixed. Pizza guy lives in my area and I was only wanting a referral. I appreciate your offering, sorry I hurt your feelings.
  #48 (permalink)
Old 02-05-2017 | 10:38 AM
I'll get over it, I'm a big boy now.
I was only irritated because you did not respond to my post.
Good luck, I'm sure Mark can help you.
( guess I lied about ignoring this thread )
  #49 (permalink)
Old 02-05-2017 | 11:14 AM
Steve Jr's Avatar
We wouldn't expect less.
  #50 (permalink)
Old 02-05-2017 | 11:21 AM
Hey Steve, I don't see you on the CAA#8 list !
Aren't you gonna join us in Eureka Springs ?
  #51 (permalink)
Old 02-05-2017 | 11:44 AM
Steve Jr's Avatar
No, but I will be at the" Dragon ". I just saw where Mark can't make it and was going to give him a shout about taking his room. Y'all have fun .
  #52 (permalink)
Old 02-05-2017 | 03:55 PM
JSK's Avatar
JSK
Deleted. Posted in error.
  #53 (permalink)
Old 02-07-2017 | 04:50 PM
drrjclark's Avatar
Thank you everyone fore the detailed directions and video on how to remove and modify the ignition. Worked great!!
  #54 (permalink)
Old 02-09-2017 | 02:02 PM
I"m not on here a lot these days.
I've used Glover's Garage in Cumming (GA400 exit 14) a few times. $90 an hour, no quotes, no estimates, just $90 an hour. They've never let me down.
Tricia in Oakwood knows of a place in Buford as well. I can ask her.
  #55 (permalink)
Old 02-09-2017 | 06:59 PM
Whitcat9's Avatar
Thank you pizza guy for the referral. I've ordered a new lock cylinder and sleeve, should be here with in a week. I'll let you guys know what the outcome will be. I appreciate all the support from this forum. You guys are the best!!
  #56 (permalink)
Old 02-27-2017 | 06:12 PM
Whitcat9's Avatar
Question; I'm about to install new ignition housing. Do I need to remove locking pin and/or the spring and pin under metal tab before installing? Thank you for your help.
  #57 (permalink)
Old 02-27-2017 | 06:17 PM
If this is a newer part it should be no trouble as the later ones did not have the pin under the little plate that caused all the trouble. To be on the safe side you could remove the little plate and see that there is nothing there.
  #58 (permalink)
Old 02-27-2017 | 06:19 PM
drrjclark's Avatar
The one pin by the clamp just pushes in and then you rotate clockwise to get ign to pull out. The spring and pin under the cover is the part that will eventually cause sticking, I would remove it now
  #59 (permalink)
Old 02-27-2017 | 07:15 PM
Whitcat9's Avatar
Thank you for your suggestions. You guys are the best!
  #60 (permalink)
Old 02-28-2017 | 04:19 AM
Whitcat9's Avatar
Well, FINALLY GOT CAR UP AND RUNNING! It came down to the ignition housing. Put new one in today, followed onehundred80 advice and checked the metal plate and yes, there was a spring and pin,took it out. Everything is great. YOU GUYS ARE TOP NOTCH MACHANICS!! COULDNT HAVE DONE IT WITHOUT THE SUPERB INTELLIGENCE OF THIS FORUM!!! HAPPY, HAPPY,... JOY, JOY!!!
