Maintenance Schedule B
Just went over my 2007 Limited Coupe this weekend per Maintenance Schedule B. Got alarm from FSS that the oil change was due so went ahead & looked over the car real good since I had the front end on ramps. Everything looks to be in solid shape & all functional checks were verified. I did see some wear on the rubber boots of the steering linkage assembly (tie rod ends). Will have to watch this going forward.
See attached file.
Later,
See attached file.
Later,
Re: Maintenance Schedule B
Found this terminal protector laying in the bottom splash cover of the car when I removed it to drain oil from pan. Somewhat surprised it hadn't fallen by the wayside. Looked around & could not see where it came from. Found one still in place on the alternator (first place I looked). Anyone got an idea where this one came form?
Thanks,
Thanks,
Bingo! There is one just like it on the backside of the alternator covering a terminal connection. If we assume that the one I found is covering a similar terminal connection (wire held on a stud post with a nut), where else would you look?
Interesting!
Interesting!
Found it! Thanks for the direction on where to look. Researched threads on starter motor and found what I was looking for. Manual even told me it was suppose to be there!
Until it falls off the next time.
