List of resettable Crossfire features
Old 04-24-2015 | 10:32 AM
Default List of resettable Crossfire features
PDF.
Keep a copy in the glove box.
The throttle body reset
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 minutes for a full alignment.
6. Drive the car as you always do.
Disabling the seat belt warning chime
1. Turn the key to ON/START - within 60 seconds, turn ignition OFF and fasten the driver seat belt.
2. Start engine and wait for the seat belt light to turn off.
3. Within 60 seconds unbuckle and rebuckle the seat belt 3 times - ending with it buckled, you will hear a single chime (sometimes this verification chime is slightly different just the same it works to disable the chime).
The chime confirms you have turned the repeater chimes off. Repeat the sequence or disconnect the battery to restore the reminder function.
Disconnecting the battery will reset the chime and you'll have to do it again!
Resetting the FSS setting after changing the oil
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and
hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
Programming the fob for one or two doors to open with one press
The fob can be programmed to open the drivers door only with one press and the passenger door and trunk with two presses. Or, open both doors and the trunk with one press.
Instructions to change the programming you have now.
Press both lock and unlock buttons at the same time and hold them down until the red light at the top of the key fob blinks twice. Repeat this operation and the change to the programming is undone.
Disconnecting the battery will reset the chime to the default setting which is opening the drivers door only with one press.
Fob programming with a new fob or after battery changes
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Setting the clock on the dash
To adjust the time display, turn the key in the ignition switch to the ON/RUN position.
The ****/button to the left of the clock is used to change the time.
Pull out the **** and turn to the left for hour adjustment and turn it to the right for minute adjustment.
Resetting the BAS/ESP light
1, With the engine running turn the steering wheel all the way to the left..
2, Turn the steering wheel all the way to the right..
A
utomatically lock the car at 9mph (15kph).
1, With the key in the ON position, press the interior lock button upper portion for 5 seconds.
Or
2, To deactivate this feature press the lower portion of the switch for 5 seconds with the key in the 'ON' position.
Thiebs (10-11-2021)
Old 04-24-2015 | 11:49 AM
maxcichon's Avatar
Default Re: List of resettable Crossfire features
BAS/ESP reset?
Old 04-24-2015 | 11:52 AM
JEFASOLD's Avatar
Thanks very much, I just printed these out. You don't get enough credit for the effort you put into this forum. This will save me much search time as my old brain just can't retain all that info. There is so much info in there now, I have to forget something in order to learn anything new! LOL
Old 04-24-2015 | 12:16 PM
ken c's Avatar
I just printed mine out and another thanks for all the work you do for the rest of us.
Old 04-24-2015 | 12:31 PM
BAS/ESP reset?
That is one that could go on the list.
Funny thing is after taking the battery leads off so many times I think my lite only came on once. I just backed down the drive onto the street and it went out.
Old 04-24-2015 | 12:34 PM
Stormbringer's Avatar
Thanks for taking the time to do this. You don't know how much time I have devoted to searching for these procedures over the years. You have made many members very happy!
Old 04-24-2015 | 12:37 PM
Mrmiata's Avatar
Seat belt chime.. there is no need for a "warm up procedure"... merely start the car with seatbelt buckled and follow procedure.
×Crossfire1× (01-19-2023)
Old 04-24-2015 | 12:39 PM
Thanks, when it is proven to be all correct I'll turn it into a PDF.
Fishing starts tomorrow so I will not have much spare time.
Old 05-05-2015 | 08:13 PM
keiranmcallister's Avatar
What does BAS/ESP for?
Old 05-05-2015 | 10:17 PM
Thread has been "stickied"
Thanks onehundred80
Old 05-07-2015 | 05:58 PM
This info was great! Thanks 180!
Later,
Old 05-07-2015 | 11:49 PM
Travish's Avatar
If I remember right, when I got mine the doors would not lock when you start driving. I did something and the doors lock when you hit something like 7 mph?
Old 05-08-2015 | 12:04 AM
Thanks for this, I have added it to the PDF. and this post.
This action will automatically lock the car at 9mph (15kph).
Or to deactivate this feature press the lower portion of the switch for 5 seconds with the key in the 'ON' position.
Old 05-08-2015 | 01:47 PM
maxcichon's Avatar
I hate the way the interior rubberized paint is wearing...wait.
It's "Reset-able"? I thought it said "Regrettable".
Old 05-08-2015 | 04:21 PM
Thornh's Avatar
+ 1 on that ...
Old 05-17-2015 | 10:20 PM
chturner's Avatar
I know I ask dumb questions on the forum sometimes but you help me so much with stuff you've posted and I want to thank you for that!
Old 05-18-2015 | 12:20 AM
Mrmiata's Avatar
Hang in there with us.. We'll beat you into shape and you can have the next newbie in about 6 months..
And the real fun is when you get to nail a senior member when they slip.. LOL
Old 05-18-2015 | 12:43 AM
You should see blue coupes repainted interior. It's as good as new, the color match is perfect.
Old 05-18-2015 | 01:18 AM
chturner's Avatar
Hey I like the sound of that!
Old 05-18-2015 | 10:06 PM
maxcichon's Avatar
I have:it's beautiful!
I'm just not sure it's worth my time/effort to do that. I think, when the time comes, I'll just buff it up, do what I can to make the interior look AGAP, and sell it on...
