How to Repair Relay Control Module (RCM) - (Mystery no Start)
Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
My turn:
2005 roadster. I had it sitting for about 4-5 days last week then went to start it. It would crank but not start. After about 10 minutes it finally did and I drove it around as normal. Tried it again the next day and it fired right up but while driving it after about 10 mins the engine died while driving it right in the middle of the road.... Luckily again after about 10 mins after trying to start it, it finally did and I drove directly home. Since then its started but stalled a few time and now it just wont start at all.
Ive replace the Crankshaft position sensor and solder the 3 rcm points and still cranking but no start. One thing of note. I disconnected the battery to install the crankshaft sensor and when I went to reconnect it the alarm immediately goes off and does every time now and the FOB doesnt lock or open the door. I had to pull the alarm fuse to stop it. And ideas or suggestions?? This forum has been a great help in the past so its always my first stop. Thanks.
i was concerned regarding the alarm going off at the worst time so i disconnected it.
i read this somewhere:
"you can unplug it. Mine failed and the batteries inside it leaked and destroyed the circuit board. I actually removed it and drove the car for a year without the alarm / siren installed. I had no issues. . You need to remove the windshield wiper arms and plastic cowl. Easy to do but you may need a puller to remove the wiper arms. There is a procedure available on this forum. Look through the area where all of the procedures, troubleshooting help, and data information is located. Hope this info helps."
i ended up installing 1 of those bars that lock the steering wheel. see this thread: https://www.crossfireforum.org/forum...t-devices.html
just an idea. it may be the solution too.
i hope this is the solution.
I would also try replacing the RCM or send it to tighed tighed1@hotmail.com, for rebuild . It might be bad relays. I personally replaced mine and sent the old one to tighed for rebuild and kept it for a spare.
Guitarb (06-04-2020)
Open the RCM. Turn the key to the ON position. Two of the three middle relays (engine and traction relays) should stay engaged.
The third middle relay (fuel) should engage for 2 seconds when the key is first turned to the ON position. Then after 2 seconds, it disengages.
If not, you found the problem. Email me to get it fixed.
THANK YOU, THANK YOU !!!!!!
Wife's roadster died the other day at a light, she got it re-started and got home ok. Just checked the RCM and just exactly as described, 4 out of the 6 pins had the telltale cracks around them. Had to use my 10x loupe to see them, but they were there. Got them good and hot to re-make the joint, with an extra dab of solder after the first solder wetted.
Got to love this forum...Thanks to all,
smallfry
smallfry
Well, just checked my coupe (which is two years newer and a lot less miles)....5 out of the 6 were cracked all the way around, and the 6th was starting to crack. Only took me half the time on this one, lol.
Thanks again,
smallfry
Thanks again,
smallfry
DJ Tighe ... I think on here his name is tighed1.
tighed1 (09-01-2020)
Still fixing them!
As janaly noted, email me at tighed1@hotmail.com for repair details.
on
I am not good at explaining exactly things but the ISSUE is soldering connections in the RCM. The factory did a terrible job on them and thy crack making the issue of mystery no start !! Buy a inexpensive soldering iron and pull out the RCM and there are I think 3-4 larger posts that are the issue!! It ll look for a photo and there is also another person on here that helped me!! Never had the issue again!!! Hope this helps!! OH and a new one will do the same thing!!! The above answer is the one i used!!perfect fix!! Member
tigh1 or sticky have it on there answer
Here is the sticky, CLICK.
Sometimes it is not the solder that causes trouble but burnt contacts on one or more of the relays, you could replace them yourself but you need to know how to do it and be confident doing it.
If not the get tighed1 to do it for you.
You can buy a new one for somewhere around $130 from RockAuto, I think that is a good idea and then you carry the spare in the trunk, I find that if you carry a spare you will never need it, but if it is at home or you do not have a spare you will find that one day you will need it.
New to the forum, but the consensus with the group is that I have an RCM problem. I have a 2005 Roadster that has been having problems starting ever since I towed it home from Austin on a trailer. Anti towing alarm went off first, then after having the transmission repaired I had it jacked up for oil change. After that I couldn't get it to start. That is when I got on the forum and asked a few questions that led me to getting the RCM repaired. Do I just mail it and a check to you, or is there anything else?
I still haven't leak checked it after the oil change. It's just gathering dust in my garage. Thanks for your help. You can email me at ebuz7497@gmail.com or phone @ (409) 7797007.
farinacci-net (12-11-2020)
I own a 2005 Chrysler Crossfire (coupe) limited, my mechanic just told me that the RCM needs to be replaced. He told me that he had soldered it but it won't hold for too long. What other options do I have? Do you know if Chrysler has a recall for it already?
