How to Repair Relay Control Module (RCM) - (Mystery no Start)
  #61 (permalink)
Old 12-15-2009, 02:20 PM
tighed1's Avatar
Default re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
It would be interesting to try your RCM in another XF to see if the problem follows the RCM.
I just think it's your car.
It's haunted!
Get it!? Green-ghost. Ghost. Haunted!!
Ok. Nevermind.
  #62 (permalink)
Old 12-15-2009, 02:55 PM
waldig's Avatar
Question re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
I have done a search and can not locate the photo of the horn mod. Help, I wanna add it as I have the RCM on the bench and might as well do both at once. Thanks Woody
  #63 (permalink)
Old 12-15-2009, 03:03 PM
https://www.crossfireforum.org/forum...-all-time.html
  #64 (permalink)
Old 12-15-2009, 03:19 PM
waldig's Avatar
Talking re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Tnx OM Woody
  #65 (permalink)
Old 12-15-2009, 05:07 PM
green-ghost's Avatar
OK, error 127 but heres a link to my cicci images
first is the solder, second is the horn wire...In the horn wire pic it seems like theres a small bit of copper still connected but it really waasnt and I widened the grooves even more
Login
Login
  #66 (permalink)
Old 12-15-2009, 05:08 PM
the solder pic
Login
the wiring pic
http://www.crossfireinternational.co...9_2_54_20.jpeg
I made the cuts even wider than they seem on the pic...no contact between points..pics are on my image gallery at cicci website
  #67 (permalink)
Old 12-15-2009, 05:35 PM
waldig's Avatar
THe solder joints on that board look ugly, there are maybe 6 sites that are scary to me, that needs to be reflowed to smooth them out, BIG TIME> WW
  #68 (permalink)
Old 12-19-2009, 12:53 PM
Just got a call from the chrysler dealer on my 04 crossfire. Seems the BAS and EDS light and the check engine light with the secondary air injection code have the relay box in common. They reset the codes and said to come get the car and lets see how it goes. They don't want to replace anything for now and want to wait and see if the codes come back. I'm not getting a worm fuzzy with this course of action.
Any ideas ?
  #69 (permalink)
Old 12-24-2009, 03:39 PM
Thanks DJ, just got it back today along with my crossfire ball cap I ordered off ebay..happy Christmas eve!!!
  #70 (permalink)
Old 12-26-2009, 10:24 PM
I haven't had any no start issues but, I have had problems with secondary air injection code P0410. I have removed the module and opened it up. Everything looked great. It was clean and I was concentrating on the relays themselves. I used a small finger nail file to clean the relay contacts about a week and a half ago. So far, the CEL has stayed off. After finding and studying this post I am wondering about the solder connections as well. If my code returns and I need to pull my module again, I will look at my solder connections,
  #71 (permalink)
Old 01-29-2010, 04:19 PM
I was just advised by the local Chrysler dealer that the relay control module needs to be replaced. Their cost is 625.00. Called the Mercedes Dealer and the same part is 220.00. Am I missing something here. The diagnosis is mutipul codes stored and all hve the relay in common. Is there a master parts crossover from Chrysler to Mercedes Parts Number?
  #72 (permalink)
Old 01-29-2010, 09:08 PM
tighed1's Avatar
Did you try the fix?
  #73 (permalink)
Old 01-30-2010, 08:20 AM
Haven't tried the fix yet. The car is still at the dealer, we pick it up this am. I will try the fix this pm but thought it was for only starting problems. I'll be using your step by step procedures and let you know how it turns out. Thanks Ray
  #74 (permalink)
Old 01-30-2010, 02:15 PM
Mr. Burns's Avatar
Awesome tutorial, Tighed! Thanks so much for the information and photos! THIS is a keeper for sure!
Monty
  #75 (permalink)
Old 01-30-2010, 02:20 PM
GDC-SRT's Avatar
Thanks to Valk and others.
This is it so far;https://www.crossfireforum.org/forum...t-numbers.html
  #76 (permalink)
Old 01-31-2010, 10:16 AM
I did the RCM repair yesterday and no check engine light after driving 50 miles. Thats a first.
Hope this fixed the problem. Total cost, zero dollars, Chrysler would have been 625.00 out the door. Thanks tighed1 for the info. Ray
  #77 (permalink)
Old 01-31-2010, 01:30 PM
tighed1's Avatar
Yer welcome.
BTW, I drink Corona.
  #78 (permalink)
Old 01-31-2010, 04:50 PM
Cheep at have the price. Give me your address and the mexican delight is on the way. Thanks , Ray
  #79 (permalink)
Old 02-07-2010, 11:42 AM
Thanks for the info tighed1.
I've had the 'no start', 'stall when stopping' and 'engine management light on' problems for a while on my 2004 n/a coupe. The engine management light comes on much less frequently now and the stalling problem hasn't happened for a few weeks, but the 'no start' issue is getting worse. I found a different thread to this a few days ago and decided to re-solder the joints on the Relay Control Module pcb. I looked at the joints under a Loupe and saw two potential bad joints so re-soldered all the big pin joints.
I replaced the RCM and turned the ignition to start the engine but nothing at all - all lights on but nothing at all at the start position. Tried again within seconds and everything OK. Thought it may have been the systems settling down although not logical. Did a short run with a few stop starts and no problems.
Last night I came across your post and realized I had completely overlooked the pins you highlighted - so out with the RCM again this morning and check out your pins - glad I did - real bad cracked solder! Removed the old solder and melted new in. RCM back in and decided to give the car a good run. Just got back from a 150 mile trip with lots of stops/starts no problem - and I'm sure there would have been with the cracked joints.
My Xfire is an everyday car with 75k on the clock, still feels taut and the engine is crisp as new.
Thanks for the clear pics and instructions and also (hopefully) for saving me a few Pounds.
Cheers,
Bluestone.
  #80 (permalink)
Old 02-08-2010, 05:57 PM
Larry Hitze's Avatar
Tighed1, The RCM arrived today in fine shape and a Free sticker! Once again Thanks very much I hope the beer was cold. Now if it will warm up again, the Crossfire is covered in snow with 5-6 inches forecast for tonight or tuesday night. Larry
Quick Reply: How to Repair Relay Control Module (RCM) - (Mystery no Start)
