How to Repair Relay Control Module (RCM) - (Mystery no Start)
Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
I see that the 5th relay is the air pump relay this is the one that was burnt the most and this is the only code I am seeing. I was thinking of replacing all 5 but not now. After resetting code I can hear the pump run, seams to do a lot of starting stopping then restarting right back up, takes a day or two before it throws the P0410 code. Ala_xfire if you have a relay for sale contact me. Thank you.
Thanks i have been taking adantage of all the good info to get my car running correctly. Happy to pass along the little bit i have learned so far. One eighty and mr miata seem to be the go to guys for all that is crossfire!!! Let me know if i can help with anything... EXCUSE ME ITS onehundred80 SORRY
But there are many knowledgeable people on here. And as 180 states.. Most is just cumulative knowledge from the forum we've retained or know where to find.
Think that comes from being "ate up" with this car.. and reading about most everything we can find..
If you go to the internet and enter (Mercedes Benz of fort Lauderdale parts) then select trade motion option from the list then enter part number 1705450305 you will find a brand new relay control module for $155 and change. I bought one of these and put it in my vehicle and it took care of my problem at a much reduced cost!!!
on
BUT... You just learned what so many take YEARS to learn: Parts for these cars are usually way cheaper from the MB dealer than Chrysler.
I was wondering if the joints might see too much heat or if it's just a common defect. So far three out of three have had bad joints.
Folks. Might want to take a look at your RCM's before you get stranded! Don't say you weren't warned!
One of these days after a drive I'll remove the protective cover and check the temperture of the area of failure to see if it is higher than the rest of the board.
My Crossie had this same problem where I was driving along and it just quit . The electronics worked but the engine would not crank. Had a tow truck take it to a shop and it started fine. I think the problem is this RCM so I am having the mechanic look at it next week. Thanks for posting this info and the photos as well - which I printed and gave to mechanic.
Dianne - hotwheels
"Normally" when car is warm/hot (operating temp)..
Car dies.. dash lights work etc. "Nothing" when hitting the key to start.. RCM
Car dies..dash lights work etc. "Starter spins"..won't start.. CPS
Car starts when cooled off.. but not necessarily every case..
Seems this little bit of BIG difference gets left out quite often.
I had a situation that the engine would crank, but it would not start. Is this the Relay Control Module? I tried several times over the weekend and it still wouldn't start. I had it towed to the dealer, they pushed it into the garage, the Crossfire Certified Mechanic pushed it into the stall, got in the car, and it started right up. They tried it every day for a week and it started every time. They put it on the computer and could find nothing wrong. They said there is no history of Crossfires ever having a problem like this. Now I'm afraid to drive it.
In your example I think you said the engine wouldn't turn over. Mine did.
Was the car hot when the trouble occurred?
Could be;
RCM fuel pump relay. Doubtful though.
Crank shaft position sensor.
Cam shaft position sensor.
Agree.. CPS.. even cars as low as 50k have experienced it. And my first symptom was only 10 minutes into a drive.. When it did start back up I did have a cel light on. But that isn't "proof positive" as we've seen in a few cases. If you haven't gotten a bosch replacement yet.. get one.. and the tools.. and become familiar with changing it. 10-15 minute job when you know what to do.
I wouldnt say its a 10-15 min job a srt-6 prolly double the time due to having a blower sitting on top of the motor. Tip for somebody trying to get connector lose, I used needle nose pliers (carefully). It gave me the needed about of pressure to pull it off. I only used the pliers after struggling to get the thing off with my hand.
Can someone please help , I just purchased a 04 XF for my wife , the car runs awesome , already did stickys key fix last week, thanks that was great , and after reading all the posts about the cps ,and the cam sensor , I ordered the bosch part from your web site , for the cam and crank , changed them both ,car fired right up we used it all day with no issues , hoped in it tonight and on the display for the odometer theres what appears to be two small wrenches and a number 40500 its there for a few seconds then display returns to normal and then the check engine light comes on , car runs great , check eng. stays on until car is shut off .
As far as the double wrench not to worry.. that is your oil change reminder.. Our "new" roadster was about that far behind.. LOL. Turn key to on.. press the stem twice quickly.. it will display the 40500 turn the key off.. hold the stem in and turn key to on.. keep stem pressed in...within 10 seconds it should reset to 7000 and no wrenches. It may take a couple tries for this.. and is typically to be done at oil changes... so note when your next is due. The check engine light will require the code to be read for any help.. most part stores can read them for you.
I read the advice here on the RCM and took my Crossie in with the photos of what the problem is...thank you SO much!!! The mechanic found 6 loose connections in the RCM and repaired them. It only cost me $176 and I should not have anymore trouble.
You guys are truly awesome. Thank you OneHundred80, you're a gem.
