Coolant light on-radiator fan NOT spinning
Good Evening! I'm Veronica and I've recently acquired a 2005 XF XRT6 Coupe and named her Betty. I had a black 2004 XF Limited Coupe named Bruce in 2004-2005. Loved the car and regretted letting it go. However I did manage to keep the 3-piece luggage set and a 2005 dealer brochure. I purchased Betty in Georgia and drove her over 500 miles that day back to Florida. Only light on the dash was check engine which was the Secondary Air Injection System. No issues on way home. The previous owner had done the following maintenance: May 2021-new set of tires and alignment, June 2021-synthetic oil & filter change, July 2021-Replaced parts: Bosch Intercooler Fluid Pump, Intercooler Fluid Isolation Kit, Intercooler Pump Remove & Install, replace battery, August 2021-Relay Control Module. I purchased September 1, 2021. I had put her in the garage and wasn't able to drive her again until October. Battery was dead, got a jump and went to take a car over to a friend's house. Coolant light was on and then she overheated. Waited at friend's house, got coolant (it was already full, but some steamed out), had to get a jump again, made it home. Car has been starting up without jump. So far, I checked Engine Thermostat, Coolant Temperature Sensor, 50 amp Fuse = all ok. Replaced Fan Control Module and Fan (I saw recall and there was no mention on Carfax about it being replaced). It's not overheated. The radiator fan is still NOT spinning. I'm starting again with the 50 amp Fuses which I ordered and going to start replacement there. Also the radio stopped working which I checked the fuses = all OK. Heard that there is a fuse on the radio itself? If so, where? Did I miss something on the troubleshooting? I had the car looked over by a mechanic and was told the Secondary Air Injection System was an "emissions thing" and not to worry about it right away. Think that may solve my issues? I've been working on this on my own with a bit of help on reading the threads and I'm determined to get this resolved. Thank you in advanced for your help!!!
edc01 (07-12-2022)
Re: Coolant light on-radiator fan NOT spinning
another way to command the fan on to warp speed is to pull the RCM and put some paper between the engine relay contacts.
turn the key on to just before start and wait. ( or I suppose you could just pull the small yellow fuse )
The one in the middle
Forum member PizzaGuy has always been a great help to people with this subject. He knows all there is to know about the how our cooling system communicates. He’s posted about it quite a few times but I can’t find the exact post at the moment. Maybe search his profile for posts or threads he’s started
rjoyner17
33
03-19-2015 10:59 PM
westonrose
10-10-2014 02:17 PM
ThatSweetSRT6
12-09-2011 09:20 AM
