skreem module
Re: skreem module
BTW, for the ground contact you have to remove the screw and clean the connector itself, and the spot where it screws into.
Re: skreem module
It could be a problem if the pump does not switch OFF. The pump would then self destruct in a short period of time, I do not know offhand if there is a specific code for that eventuality though.
on
Re: skreem module
FYI, I have an account with Mercedes and spoke to there parts department about getting a module from them. They have 600 in available, but will not sell them except for a Mercedes. The list price is $270.00 for the module. The local Chrysler Dealer told me they are working on a supplier,hopefully by Oct. 15th but do not expect them to be available before December. Chrysler list is $577.00.
I would also like to have a spare one just in case.
suppose you can get the module from mercedes. just suppose. what then? what about the match with the VIN? how can it be used with a croosie? what you have to do to have it replacing the 1 you have? programming? how? who has the knowledge and the tools to do that?
thanks
Re: skreem module
i would like to understand what do you get if you have 1
thanks
thanks
