RCM wiring
Re: RCM wiring
I just looked under the hood of my 2005 roadster and think I know what you're referring to. The connectors you're referring to have a gray cap, right? The caps appear to be hinged on the driver's side when they and the RCM are in place. I can probably get a fairly good pic of them tomorrow, but the pic won't accurately show which connector pin each wire goes to the problem is complicated further by the dull colors on the wires.
What will happen if I open the caps on the connectors to accurately show where each wire goes? Will the wires slip out of the connector with little or no force? have to know before I proceed. We have one Crossfire out of commission now, and I don't want mine to be the second one for the same reason.
Re: RCM wiring
Starting two threads on the same subject with the same name confuses everyone, people answer in one thread and then find something different in the other. Just start one thread, I thought I was going nutty when I could not find one answer I had seen.
on
Re: RCM wiring
Posting multiple threads on the same problem DOES NOT get you faster answers, it only makes a mess, as Dave said.
(Dave, are you are "Faulty Towers" fan?
Re: RCM wiring
Yes, you are exactly correct. I have mentioned earlier that I was not familiar with posting on a forum. I never knew what I was doing. This is a everyday thing from many of you, not me. I need help with this programming the switch. I don’t know how many times I’ve found people on Google telling me what to do. I just need some help. Thanks
Re: RCM wiring
I watched it back in the day sand liked it, it can now be seen on BritBox here which is a video streaming service for UK TV shows.
tighed1
07-01-2024 12:53 PM
chelseaccox85
12-18-2008 01:16 PM
