Let's discuss the key fob transponder chip(s)
Re: Let's discuss the key fob transponder chip(s)
CQ CQ CQ DX
My mobile rig has been in a box since returning from Saudi over 20 years ago.
Everyone had these little radios called cell phones with better range than my 2M rig, oh well - BT
pizzaguy has it right on.
My understanding is that these remotes do not lock to specific vehicles, the transponder does.
The FOB/Remote can be reprogrammed to other vehicles by inserting the key into the ignition switch, press either the unlock/lock twice, then turn the key in the ignition to the ON position within 30 seconds. So in a way, it is a universal remote. Have I tried it on a crossfire myself, no. But I would like to own one and upgrade the engine to a V8 along with testing out all immobilizer theories .
K5WX here. I'm currently sitting at 99 countries confirmed for my DXCC. Goal is to get number 100 confirmed by the end of the year....and almost all of them are using CW, low power, and wire antenna.....!
Good idea but a key will not fit every car, so you cannot turn it. I think only when the SKREEM recognizes the chip will it respond to the boards signal when inserted in the ignition and authorize the synchronization. Other keys that fit and turn will be ignored because the chip does not match, seems logical to me.
That said, after disconnecting the battery and replacing the SKREEM, I twice clicked the fob from outside the car, THEN inserted the key, turning it to ON/RUN within the 30 seconds.
The new SKREEM accepted the fob RKE code and the lock/unlock functions worked A-OK.
So, the key does not have to be in the halo when pressing the fob button.
Agree with 180; the SKREEM will only accept changes to the RKE lock/unlock code if the Fob chip code matches the SKREEM's.
There is a thread here somewhere that a guy posted that after purchasing a key from a dealer the dealer said for $100 they would program the key, the guy laughed, pointed the key at the car, hit the button twice, sat in the car, started it and waved as he drove away.
Hi
For anyone that wants to experiment with making/duplicating their Crossfire keys. The correct blank chip to use is a PCF7935AA
Like these ones on eBay: https://www.ebay.com.au/itm/10PCS-PC...s/172143666760
You can program them with this: https://www.ebay.com.au/itm/OBD2-Min...w0E9:rk:1:pf:0
Have fun!
Have fun!
Hi
Have fun!
Have fun!
We would clone the chip and get the key blank cut to our original key.
We could not remotely open or close the doors or use the alarm.
We would just use the physical key to lock/unlock the doors, hatch and gas cap.
Would we need to remove the chip from our original fob which seems to be risky at times or leave it in place?
We could make back up keys as insurance in the event we lost keys for much less money than buying a new key.
I listed this information because this is what I use and it works fine for me!
I'm also looking at the SKREEM modules with another forum member and I'd like to know from someone who has had a SKREEM failure if the no start issue effects all the keys for the car or just one key? If someone can tell me this it would narrow the failure down a bit.
OK, if we had the above listed items could we duplicate our key using a blank fob shell.
You don't need to remove the chip from the key fob. You can place the key fob in the machine and read the file from the chip, no problem at all. When reading the key or writing a new chip, you need to make sure its vertical in the receptacle, otherwise it wont work
Thanks for the reply. I'm trying to narrow the failure down a bit. From what I've read, the same DAS system is used on the latter model Electronic Ignition Switch (EIS), the SKREEM and the EIS both use the same Motorola CPU chip to store the key information. BTW, the immobilizer in the EIS's also works with our Crossfire ECU (which is another solution if nothing else works). When the EIS's fail, it's usually because the file on this chip gets corrupted. It's only a small file and I've been trying to work out it's format. I have a decoder that can read these files and give me the information for the eight associated key files (so I can make the keys) but I want to try and work out where the serial number it shares with the ECU is kept. I expect it will take quite a while to understand the basics of these files.
Any idea if this is the same reader/programmer ? Also is the same chip used in the valet key ?
Yes, it looks to be the same and should do the job. I use mine on an older laptop that runs Windows 7 32bit, make sure you follow the instructions when setting up the software. I don't have a valet key for my car, but it should be the same chip.
on
CL770/RED DOG/ onehundred80 - Gentlemen - I've read the post's that all of you have made and I prompted up the ebay ad for the reader/programmer. I read the entire description for the tool mentioned but I can't make any sense of the description. Too many shortcut initials for me. I don't understand the description at all. Can anyone write up a "everyday English" description of the tool, what it can do, how to do it, and what transponder chips are used to duplicate a busted up key fob? On the ebay site you remember "Autel" as the company or manufacturer. They also have a listing for blank (I think) transponder chips. Several, and with many different descriptions. That too, is confusing and to the everyday home car jockey, has too many numbers and initials.
Is there a everyday English translation to all this electronic description that the layman can understand? If so, please point me in that direction. I would like to try and understand what this tool and the many chips do.
Thanks,
Jim
Thanks,
Jim
Thanks,
Jim
Thanks,
Jim
A valet key should;
Open drivers door.
Start the engine and allow the car to be driven wildly up a winding driveway to the top floor of a parking garage with the sound of screeching tires echoing back down to you. This of course ruins the grand meal you have waited months for and will be paying big bucks for. Knowing full well that the same thing will happen when they bring the car back down and deliver it back to you in a cloud of smoke. You will of course ignore the hand held out for a tip. If you are lucky there will be no dents and no significant miles added to the odometer. As you drive away you will see in the rear view mirror the car jockeys waving and smilingly at you and giving each other high fives. You may or may not see the time to get to the top floor chalked up just like on Top Gear. That’s when you decide that next time you’ll take the clapped out wreck your kid drives.
OY.
Ok I have received the five RFID chip. Programmer from eBay should be here on the 8th. The "valet key" below can manually open the door or trunk and operate the ignition/start/run the car.It just has no remote capability.
By the muddle of January I should be able to answer other questions.
Anyone know where I can get just a circuit board ?
