Seat Belt Indicator Light
Old 06-05-2018 | 08:45 AM
hr_collier's Avatar
Default Seat Belt Indicator Light
I'm a new 2005 Roadster Limited owner and I am noticing that I do not get a Seat Belt Indicator Light when I have a someone in the passenger seat and their set belt is not buckled. Is this normal? Shouldn't I be getting a warning to indicate that the passenger (when they are there) is not buckled? I am also concerned that if the car does not realize a passenger is seated that the air-bag system would not correctly deploy in an accident. Any advice? Thanks.
Old 06-05-2018 | 08:58 AM
Default Re: Seat Belt Indicator Light
It is possible to switch of ghat air bag using the key in a keyhole visible when the passenger door is open. The light beside the ashtray should light up if that is the case. The airbag is switched OFF when a rear facing a by seat is used.
Or someone may have disconnected the wiring to the seat belt to prevent the alarm.
AlexParra
12-09-2013 02:10 AM
blackoutken
01-25-2012 11:21 AM
ant.lan
12-12-2011 12:00 AM
khanable
07-21-2008 07:44 PM
upstate
09-02-2006 07:28 PM
Quick Reply: Seat Belt Indicator Light
