Alarm Question
Alarm Question
Recently (have had the car for five years) on two occasions the car alarm has gone off for no apparent reason. I would also note that the battery is new.
Pulled the number 9 fuse as a temporary solution. Checked the various threads and went ahead and disconnected the siren in the cowl as I really don't need an alarm. My question is this -- by disconnecting the siren does this completely stop the alarm from engaging? I did notice when the alarm went off that in addition to the siren the lights also flashed and am now wondering if, with the siren disconnected, the alarm system is de-activated?
Re: Alarm Question
Here is what I suggest, make sure you do not have water in the lower part of the 'trunk/hatch'. Another thing to 'consider', when that siren WAS triggered, was the lights flashing (as they should be)? If so, and the alarm is still tripping (without the siren, as modded), is there still a problem (like the lights flashing), and what is CAUSING it? I would suggest you check for that water in the lower back compartment, if it is the source of your problem, it'll only get worse and a lot more expensive if that module gets ruined.
