BAS/ESP & Speedomoter doesnt work; stuck in 1st when LIT
Re: Miami Crossfire issues BAS/ESP & Speedomoter doesnt work. Stuck in 1st gear when
No Speedo - Limp mode - Dash lights Issue
When I had the No Speedo, Dash lights lit, and car going into intermittent Limp Mode -- it was the ABS module.
The car ran but if the dash lit up while stopped (at a red light/traffic) it went to limp mode - only a restart would clear.
Bought the ABS module for $140 on ebay and had the local mechanic install. Car ran like new again.
See pic for Dash lights - No speedometer - Limp Mode error
I had that issue for months and it was the toughest to diag. Really frustrating.
Checked the Electrical > Replaced the Speed Sensors > Had the tran fluid level checked (which was goofy cause the car never leaked anything) > checked the Brake Pedal switch.
At that point it was the limp mode that told me it must be the ABS.. they replaced and bled the brake lines. Make certain they bleed/flush them.
*I changed the Speed Sensors first because it happened soon after new brake pads were installed. I never saw any leaks / Brakes were strong -- so I figured the brake lines were ok and no bubbles.
..but after the fix I always wondered if maybe there was air or bubbles in the brake line that tripped the ABS/Limp mode. I'll never know.
lgonzalez
05-31-2019 11:55 PM
waldig
08-02-2018 09:02 AM
KDW4Him
21
05-13-2016 09:47 PM
autumnmass
09-22-2014 08:57 AM
04-08-2014 05:31 PM
