Spoiler activation and interior light issue
Re: Spoiler activation and interior light issue
I must apologize, I have scanned through all the service manual information and cannot find exactly what drives the speedometer, or the cruise control.
I can find all the wheel speed sensors, but they all seem to feed just the ABS module.
Also, the automatic transmission has 2 speed sensors in it, but they just seem to feed the TCM.
I guess it is entirely possible that either or both of these put messages on the CAN bus that the PTCM reads to determine the current vehicle speed, and thus control the speedo and cruise, but I can't find anywhere that it is stated.
Bottom line : I ain't got a clue.
( In my business, this issue would need to be escalated to level 2 or level 3 people for an answer, but unfortunately we have NO L2/L3 people, unless someone wants to chime in )
Okay here's a question since the TCM monitors all electrical functions of the transmission and some hydraulic if there were a problem with the internal speed sensors would it not register a trouble code?
On a DRBIII setup.. I'm sure it does.
Hi !
I used an OBDII to read the error code but there is nothing found with that. I have no warning light on the dash board. So as written previously, do you think an OBDIII can read an error code due to a bad speed sensor, even if there is no warning lights ?
And do you have any recommendation for this kind of device ?
Thanks
Thanks
Hi !
Thanks
Thanks
Travel plans to Arizona?
I just helped a facebook member score the multiplexer cable off Ebay.. he now has the complete setup.
Right around $800 for just the cable..
He just reset his Tire Pressure Monitoring System.. and has offered to help others.. Not charging - but donations accepted..
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
