battery light
battery light
A week ago my battery indicator light turned on. I checked the voltage when the car was on and it was reading 11.79 volts way to low it needs to be around 13.25-14 volts.
that only means my alternator is bad so I replaced it then the freaking light returned ugh!
I took it back in my car to the alternator shop. The owner did a few test and noticed my battery was low he asked if he could charge it up for a few minutes so i agreed.
The battery was on the verge of dying, so I bought one from him.
I have a new alternate and battery all should be good right? No the alternator wasn't delivering the right voltage the diodes were fried!!! This happens when your battery is low and the alternator does not charge a battery it just maintains the voltage. If I just changed out this old battery my original alternator would have been just fine.
The shop fixed my alternator after a $179 alternator $111 battery scraped knuckles and a wasted Friday morning..
She works now I had to drive a few miles to get the battery light to reset al is well...
Re: battery light
Seriously people, these are 2 bucks each and would save many battery/alternator heartaches.
I've had them in my cars for 5 years now .....
DC 12V 24V LED Display Cigarette Lighter Electric Voltage Meter tester For Auto car battery voltage indicator-in Voltage Meters from Industry & Business on Aliexpress.com | Alibaba Group
Re: battery light
Re: battery light
Re: battery light
I am not sure of the above statements, I have had cars for 50 odd years and all but one had an alternator, I have had batteries die on me and I have driven the car to get another battery. I have had to replace only one alternator in that time and it was because I could not put it back together after looking for a bad bearing.
The battery acts as a buffer and spikes are absorbed, running a car with the battery being disconnected after starting or jumping may cause problems though.
Re: battery light
The battery acts as a buffer and spikes are absorbed, running a car with the battery being disconnected after starting or jumping may cause problems though.[/SIZE]
Well that`s exactly what happened to me
Re: battery light
So i ended up getting another alternator and everything was fine, till I drove it to work and the ride home the tranny would`t shift out of 3rd gear (it`s an auto). i drove it a few miles i got off the highway turned it off, then back on and everything was back to normal. I immediately logged on to this forum , the issue seams to be limp mode. I have a couple questions
1 could this be related to my battery/alternator issue
2 will this issue continue
3 how can i repair this or must I take it to a dealer
thanks any advise will help.
Re: battery light
I was reading the comments and saw this statement, I was hoping i did`t have a next post but sadly I do.
Re: battery light
See if someone can read the code for you. I am not sure if the normal reader can find tranny fault codes though.
This would not be caused by the alternator or battery.
Re: battery light
Hello Everyone..., so , I replaced the alternator on the rescued SRT, it had begun whining. After finding that Rock autos, " fits both versions" did not fit both and got their Valeo no-core charge replacement instead, it was a closer match and able to be mounted with connections made. Its quiet with no bearing noise, but now, at 2500 RPM or higher, the battery light comes on and goes back off when the RPM's settle down. Belt seems tight, reckon it's slipping or is this some other issue? Thanks in advance...Peace
Re: battery light
Re: battery light
First, get one of those el-cheapo cigarette lighter voltage readouts and watch what is ACTUALLY happening.
Re: battery light
But I STILL would take a close look at belt tension and condition before I order a new alternator. If the belt is loose enough to slip, it will be obvious - and it may also cause some power steering issues as well. Have you had any indication of overheating (water pump pulley slipping)? Again, for it to be that loose, it should be obvious.
Re: battery light
Re: battery light
But why would the light come on?
Re: battery light
It would have to slip enough such that the alternator produced less than battery voltage, that is how the light works -and given that the alternator can charge at idle, I'd say the belt would need to be damn loose -seems to me the power steering and maybe even water pump would be effected.
I'd check the belt tension, but I'd also bet $20 that the alternator is just plain flaky.
Re: battery light
Re: battery light
I don't actually think that cause it does NOT make sense - like I said, if the belt is THAT loose, seems like the steering pump and maybe even water pump would be suffering, too.
