Starting issues...RCM related?
The problem started this way, and it may just be coincidence but......
One day I started the car, went to back up, and stalled it due to forgetting to release the e brake. I tried to restart it and got nothing....no click or anything. My first thought was dead battery, and as it turned out, it was in sad shape so I replaced it. However the problem persisted.
When I try to start the car it will start, sputter and die unless I can coax it to above 2k rpm or above. I can usually get 2 or 3 tries with the key actually engaging the starter before I get nothing from turning the key.
Disconnecting the battery for 30 seconds or so will give me another shot at it (I assume I am resetting something, maybe a security circuit?) and it usually will stay running. I still need to race the engine to 2k or so, but once I do it idles and runs fine.
I have checked the RCM and it looked fine, but I did heat up the contact points and add a bit of new solder to the ones I have read are the most common problem. The only thing I can assume is the RCM is going bad, but not failed completely yet.
I have read several similar issues that would indicate the RCM, but what I'm experiencing seems to not quite match.
Any ideas or suggestions?
Re: Starting issues....RCM related?
I think the pressure regulator quits working. Maybe it's the check valve, that's on the pump I think.
on
interesting new symptom......stopped by my moms for a few hours today. Her driveway has a bit of an incline and so I parked for several hours with the nose uphill. When I went to leave it just wouldn't start. I tried several series....three turns of the key each with the engine catching and dying before turning the key got me nothing. Each time I would disconnect the battery and try it again.
After doing the "battery reboot" 3 or 4 times, I rolled it back into the road, which is level, and after 3 battery reboots (each with 3 good key turn/engine catch and die) it started right up.
My thoughts are leaning more towards the filter, thinking the debris may have settled with the car parked on the hill?
Check the fuel pressure! You need to eliminate possible causes and fuel pressure is easy to check. You need 3 things for an engine to run. Air, fuel and spark. It's difficult to have an air blockage bad enough to keep a car from starting. Fuel pressure is an easy check, do it. Spark on modern cars is a bit more complicated. Eliminate air and fuel problems first because it won't cost you much or anything at all. If you don't use logic and the process of elimination you'll end up throwing more $$$$ than necessary at the problem. My humble and "the hard way" learned assessment.
Les
Les
Les
Les
Hi Guys
I'm a British serviceman currently stationed in Dijon, France. I've been having startup issues with my 2004 crossfire (manual) for sometime. Clearly in France the language problem exists and lack of qualified mechs!!
The symptoms are similar to what I've read about on this stream already but seem to be a lot worse, if not exclusively occurring in the cold/rain (something that hasn't been mentioned on the stream. They are:
1. Car drives......after a while (in poor weather) multiple dashboard lights come on and the speedo / RPM and engine heat dial all drop to zero. Car will still drive normally.
2. If I turn off the ignition while these problems exist I have trouble restarting. The engine will start and die immediately (as if it was immobilized). I can do this 3 times and then I get nothing. If I wait a while it will often start again, especially if I've opened the bonnet and removed the fuze box covers etc.
3. If driving but in the city, often the problem will come back AND the radiator will go crazy, making a really loud noise.
I've read about the RCM maybe being the issue and I'm REALLY interested in the thoughts of people on here who seem to know what you're talking about.
I've taken it to the Chyrsler garage here (well it says it is, but is now fiat) and they don't have the diagnostic computer (after keeping it for 2 weeks!!). I've had it serviced but the problems remains.
The weather here is no great and the car is running no problems. I must have started and stopped it 10 times this morning alone with no issues at all. In addition, I removed the cover under the engine and cleaned the earthing cable. It was green and is now back to bronze....could this have been causing or adding to the problem?
As I said, I'm convinced it's an electrical issue, linked to wet weather.
Thanks in advance for ANY thoughts you may have on the issue.
Dave
Dave
Hi Guys
Dave
Dave
With all the rain is it possible that water has got into the trunk and messed up the pump that controls the door locks and by default a lot more besides?
Fuya
15
05-15-2017 11:09 AM
pioneer4x4
01-26-2016 01:41 PM
