Only third brake light working
Old 11-30-2016 | 06:53 AM
Default Re: Only third brake light working
From the manual :
Old 11-30-2016 | 09:25 AM
cartoonguy2002's Avatar
Thanks so much!!! I figured it was something to do with the spoiler!!
Old 12-02-2016 | 10:54 AM
This brake switch video is not exact, but it's close enough.
Old 12-07-2016 | 09:53 AM
Old 05-08-2018 | 01:19 AM
Marcorosales's Avatar
Originally Posted by dobermann
I got this fixed (finally).
I took the turn signal switch out to see if there was an issue. I was going to buy a new one but when I put it back in all three lights were working.
I'm not sure what the exact problem was but I read that the interrupter in the turn signal switch can cause the brake lights problems which is why I removed it.
At least they all work now! So if you have this problem that could be a solution for you too (for anyone reading this).
this may be super out dated and late but if I may ask what steps did u take to remove this ?
Vipor3D
11-10-2015 09:36 PM
deltacrossfirebob
16
10-20-2015 03:38 PM
jmk41
10-05-2015 01:33 PM
mandingo_rick
10-04-2015 12:45 PM
09-25-2015 02:16 AM
Quick Reply: Only third brake light working
