Needwings Map Sensor
I was wondering why my intake temps are so high 70 outside intake temp 149,well I odered a new svt mustang pump I alraedy got a Johnson pump.The map sensor I got from needwings has a single probe instead of a hotwire like the one I had an the one pictured on there website.I have a hotwire type sensor on order from eBay so I really have a feeling it's the sensor an not my Johnson pump,I have never had temps that high maybe 20-25 degrees over ambiet when its hot weather now may 8-10 degrees.If its the sensor I will relay the info to needwings.
Re: Needwings Map Sensor
Just got my ebay map sensor car intake temp is ambient as normal reinstalled the sensor from needwings 150 degrees,well I have a better pump coming anyway hope this helps someone who have very high install temps after installing a new map sensor,also emailed needwings about the sensor,just so they know Mercedes is sending out the wrong sensor.
RED DOG
18
05-15-2016 03:46 PM
livefreeordie
11-23-2015 02:36 PM
