map sensor
Re: map sensor
Hopefully this will help someone out,my issue was lean code on bank 2 cat ,and bank 1 under threshold,well the driver side cat converter was clogged cause the passenger side converter to blow out plus gave me a exhaust leak,I replaced both exhaust manifold gaskets,gutted the other converter reinstalled going to use O2 elimenators from needwings,I have a fullflow exhaust with just a stock muffler.Also replaced the wires 90k miles on them,replaced the map sensor and redoing the fuel system,going to feed boost to the stock fuel pressure regular and adjust the pressure with nitrous jets to hopefully a 11 a/f ratio.Its will be interesting to see how the new headers are installed besides remove the engine probably could install them after you remove the valve covers.Yes my performance did fall off before I was getting the codes so today after work install the coils packs and do some testing.Anyone cappped off the evap cansiter and have issues if so please chime in.
burnzboy2
15
11-01-2015 03:17 PM
