hood scoop.
Re: hood scoop.
Steps, all I need to do to make my scoop functional is remove the inserts that sit behind the mesh covers. I chose not to for several reasons. Even though opening it up would allow some cool outside air under the hood to help alleviate heat soak, I really don't think it's necessary since I don't have a pressure cooker/supercharger to heat things up.
If I wanted to use it as a cold air introduction system, I'm pretty sure it wouldn't work nearly as well as the NeedsWings CAI.
I had mine built purely for looks, and it's met and surpassed all my expectations.
If you're looking for some under hood heat removal, I'd suggest taking advantage of the high pressure area at the base of the windshield by installing a cowl induction scoop there, Something like the 1969 Camaro used. Good Luck.
Re: hood scoop.
Here is the easiest start, Woody
PS I made my own Va. accepted hood NEGATIVE hood scoop = see my gallery for details.
https://www.crossfireforum.org/forum...econd-fix.html
Re: hood scoop.
To be functional you could (would) have 2 NACA ducts way on the leading edge of the hood to feed air air into the OEM airbox/engine cover.
http://www.dsgperformance.com/assets...rmance%203.jpg
http://image.hondatuningmagazine.com...naca_ducts.jpg
Re: hood scoop.
Re: hood scoop.
I love the looks of the Crossfires, Coups or Roadsters, they are all beautiful. That being said, Chrysler incorporated their signature hood on them; my guess to keep it connected to their line up. To me, it's the weakest part of the design. I would have preferred the multiple side curves removed with just a center ridge remaining. A hood scoop would have been better yet. I had a '70 Cuda after I got back from Nam, I would have really appreciated similar hood scoops on the Crossfire, especially the SRT6. I may pick up a used hood to play with, it's not a high priority but it has been hanging around a bit.
I've always enjoyed Fireamx's hood.
Dave
Dave
Re: hood scoop.
What Jaguar ones?
Re: hood scoop.
Use search to look for Jaguar vents.
Re: hood scoop.
What part of "representational images intended only to show 2 types of NACA ducts" is difficult to understand?
The images I referenced are of what I speak, though there many, many, many other iterations of NACA ducts.
I found Supercharged hood vents (Jaguar) on this site and they are certainly not NACA ducts.
Re: hood scoop.
07-25-2015 08:01 AM
