2004 Crossfire Vibration
Hi,
Firstly I am new to this forum so apologies if I am posting this in the wrong place!
I have owned a 2004 Chrysler Crossfire (Auto) for over a year and for the last month it has developed a loud vibration when the car is going at around 30-40 MPH (Or between 1000 - 2000 RPM). The vibration is reduced greatly when I manually change the gears. It has also stalled a couple of times when slowing down to stop at a junction. Its been in the garage a couple of times and nobody seems to be certain of what is causing the issue however there doesn't seem to be any Chrysler specialists in the Newcastle area (Unless someone knows otherwise?). The latest diagnosis is that there is something wrong with the gear box and it may need replacing but the estimated cost is around £2k.
I was wondering if anyone else has come across this issue and if so could they give me some advice? Also can anyone recommend somewhere that may be able to supply a replacement gearbox at a decent price if this is likely to be causing the problem? I have read that this can be caused by a faulty Transmission Module or Solenoid but there doesn't seem to be a definite answer.
Any help would be greatly appreciated as the wife and I both love this car and would hate to have to get rid of it!
Thanks in advance.
Darren
Thanks in advance.
Darren
Re: 2004 Crossfire Vibration
Hi,
Thanks in advance.
Darren
Thanks in advance.
Darren
Hiya Darren! Yeah it sounds like the dreaded transmission/solenoid plate area problem (name escapes me at the momeny cuz of a brain fart) if you do a search top right for auto shudder or solenoid or plate you might find the posts referencing the particular symptoms/fixes. According to how experienced you are, it may need to be done at a transmission shop. Since you didn't show your location top right, it would be a little harder to help with some of the folks here who are more helpful with this issue. Anyway, welcome to the forum, there are a whole bunch of assets here for the XF owner.
Hi, thanks for the quick replies!
Sorry I should have probably mentioned my location, I am indeed in the UK.
I have managed to find a place that is a transmission specialist so think I'll take it there so they can have a look. Hoping it isn't too serious...or more importantly too expensive! I'll update this forum with how I get on.
Thanks again.
Thanks again.
victorlautreamont
06-29-2017 01:22 AM
ultrajim49
17
06-27-2015 12:20 AM
adamlevy
06-07-2015 08:13 PM
