Driver side window problem
driver side window has about a 2 inch play in it
it rattle over any bumb i go, has lots of wind noise and when i wash the car i get some water inside,
i showed it to my mechanic he said it can be either an adjustment, or clips or might need a new regulator
we are going to open the panel monday and check the problem, does any one have a similar experience.
Re: Driver side window problem
See also the thread this picture came from by clicking here.
Here is a photo of the door with the panel removed and the adjustment points indicated. Driver side door will be the same.
BrenLW
08-05-2015 05:53 AM
