Steering wheel centered?
Guest
Posts: n/a
Actually I did test drive my car, and I did notice that the wheel did not seem centered, but having only driven the car for 15km I was not sure that it was not just the roads that I was driving on. I though maybe just the crown of the road was making me steer the car more to the left. But know that I have had the car for a week end and put a little over 200km on the car it is obvious that the steering wheel is not centered. Oh and by the way I am not in a panic as I am fully aware that this is not a serious problem that can be fixed with an alignment. I was just wondering if perhaps someone else out there had noticed a similar problem.
both cars I test drove at the dealership where to the left. i was enough to the left that I noticed it right off the bat. The one they pulled from a dealership that I bought is dead center.
If mine was *** much off as the ones I tested i would have had then realign it with the wheel set straight.
-marc
-marc
Getting it centered is a major pain in the @ss. I had my steering wheel replaced (was scratched). The new one was supposed to go on straight. However, that wasn't the case. It was a little off. I had my car realigned. It still isn't perfect, but good enough.
It is a pain to get it perfectly centered. The little slack in the steering doesn't help. I was there through the entire alignment process. It doesn't pull, just a hair off to the left.
Steering wheel off center
I recently ran over some debris in the road and distroyed a tire. The dealer put on a new tire and the car needed an alignment. The dealer tells me that they do not have the proper tools for the alignment on a crossfire. A wheel expander tool is needed. Has anyone else experienced this situation? They did a standard alignment but the steering wheel if off center to the left a lot. The dealer is trying to find the tool.
I had the same experience. Needed to replace a 19" tire and wheel, ouch, very expensive. The dealer had to find a special apparatus to balance the tire. They did and got the job done. I learned later that stores that sells and services Michelin and Continental tires could also handle the job.
Paul V
Black XF
Paul V
Black XF
livefreeordie
09-22-2015 08:13 PM
cdcrone123
09-20-2015 10:02 PM
