Tough Manual Shifting
Re: Tough Manual Shifting
honestly that is how the manual is on this car when cold the first, reverse and second can be kinda klunky.
let the car warm up a bit and drive it easy the first couple miles till the fluid work through and warm up a bit
not sure about the fluid i thought it was good for a while
i have a 08 limited and when cold i experience same issues
Originally Posted by markfothebeast
The transmission is tough to shift in and out of gear when cold (6-speed manual). When warm, it is still a bit tough to shift into gear, especially 1st and reverse. The car has only 34,000 miles. Any ideas? Should I have my fluid changed out? Thank you.
I really can't say the synthetic oil improved it, actually I think it got a little worse. At least until it warms up.
Most people think the tranny shifts better when you accelerate harder, but that's not always the prudent thing to do.
oh yeah i forgot shift around 3k-3.5k and it should be smoother transition, blip throttle a little upon shift and try to rev match
oh yeah one more thing try driving around one day without traction control it is fun especially when you shift lol .
Even though manual can be notchy in the morning once you warm it up i love the manual over an auto. now if you live in a big metropolitan city that is gonna suck
I would try it.
Make sure you use the right fluid as using plain old synthetic "Autozone" Manual Transmission Fluid can make your transmission feel even worse.
On Japanese cars, I've had great luck with Acura MTF 08798-9031A. Not sure what to recommend for the XF, but there has to be a Mercedes equivalent.
Maybe I'll take it to my local mercedes dealer and have the fluid changed. It's hard to shift into reverse all the time. You really have to snap it into reverse. As for shifting into 1st, I usually slide it through 2nd then into first and it's easier. Sometimes double clutching makes it easier. It's just not right for a car that cost $35,000.
Try either 0W-20 or 5W-20 synthetic oil.
I switched to Amsoil 0W-20 last Fall with some cold weather shift improvement, BUT, this is just a rough shifting manual tranny when cold by design.
https://www.crossfireforum.org/forum...ghlight=harbor
I disagree.
Do not attempt to use synthetic engine oil of any variety. The shifting will get worse, guaranteed (ask me how I know!)
If you choose to use something other than an actual MB MTF fluid, then use the Acura MTF I mentioned.
Gear oil and engine oil have completely different shear viscosity and additives, heck they even smell completely different. Very, very different stuff.
Originally Posted by sonoronos
I disagree.
If you've had problems, let me know so I can replace my fluid.
PM me if its a long story.
Thanks!
Originally Posted by harbor
Sonoros - Give me some more detail on this please. My owner's manual lists 5W-20 engine oil as an acceptable replacement fluid, as long as it meets API SL or GF3.
How I know from experience - I only drive MT cars and did my first 5MT fluid swap on my brother's DC2 Integra @ 140,000 miles. We pulled out his owner's manual from 1995 and indeed, it specified synthetic 5W-20 engine oil meeting "API SL or GF3" specs. We drained the fluid and refilled to spec with engine oil. Immediately afterwards, he complained of poor shifting. I verified. Gears were grinding on shifts, the gearbox felt notchy.
After 3000 miles, we completely drained the gearbox, refilled with 08798-9031A, and the shifter felt better than new. I'm talking about S2000-style gearbox performance. Completely transformed. The change was instantaneous by the way. The instant the new MTF was put in, the shifting performance was restored.
Engine oil = bad. You may also try GM Synchromesh semi-synthetic with Friction Modifier, #12377916.
I still think the Acura fluid is the best.
Wouldn't a Crossfire transmission have a different reaction to fluid for an Acura? I had trouble with a MT on a Mustang and swapped the fluid out with a thinner synthetic auto trans fluid and it shifted better than any vehicle I've ever owned. The stock gearbox fluid was too thick for the galley ways and the transmission fluid wouldn't circulate fast enough to make shifts easy (from what I read). But apparently the fluid has to act as a coolant at the same time and disperse the heat.
Does anyone here have a Crossfire that shifts smoothly?
If you put in ATF into a Tremec box and got better shifting performance, then you most likely lucked out, and/or the original fluid was in fairly bad shape.
ATF is designed for a very different kind of transmission, which uses a torque converter.
ATF, MTF, Engine Oil - all different.
Use an actual MTF, like GM Synchromesh or Acura MTF, and if you really feel like spending $$$, you can use stuff like Royal Purple, Amsoil, etc.
I would suggest sticking with whatever Chrysler specifies for the MT6. There are good reasons for manufacturers to select certain fluids.
I have two MT6s and both are relatively hard shifters, compared to my old 2002 Vue MT5 and both my Audi's (A6 and A4) with MT6. It's the nature of the beast. The roadster, now with 32k miles, has gotten easier as it becomes more "broken in". Eventually you will find the sweet spot to go from 1st to 2nd. Reverse is not a problem on either car. Consider it one of the idiosyncracies of the car, like the electrics on an old Triumph.
Here's a link to many, many reviews of GM Synchromesh Friction Modified on the web. Reviews are glowing.
http://www.google.com/search?hl=en&q...ed&btnG=Search
Sonoronos, do you currently have a 6MT XF and if so, what are you running and how does it work out? I have the same problem and want to make sure I only have to drain and purcahse once. Since I know very little about these things, I will trust your advise. Thanks in advance.
John
John
05 - I have a 6mt xf in my garage in MN with 5k miles. The shifter has been just fine from the first day that i bought the car.
I plan on changing out my mtf with GM Synchromesh with Friction Modifier @ the first 2 wrench service, you may have to wait a while before that happens - sorry.
As for what fluid to use, don't take my word for it. Just read around, take my opinion as one of many...
