Crankshaft Position Sensor
Re: Crankshaft Position Sensor
Hello, I have changed the Crankshaft Sensor as well as the camshaft sensor, all new spark plugs, checked every coil pack with a good one, tested a spare RCM and re-soidered mine (Paul D did the work) Also replaced the fuel filter and checked fuel pressure which was at 52 psi. Can not find any vacuum leaks but cylinders 1 2 3 are not firing. Can unplug all three coil packs on that side and it does not change how it runs. It is smooth as can be at 1,000 rpm and up but will not idle proper. If you rev it up to 2,500 it will hold it for 5 seconds and then drop down to 1,000 and cycle like that as long as you want to hold it there. Anybody have the same situation and now what to try next ??
on
Either those coil packs are not being triggered by the ECM (in which case you need a new ECM) or the fuel injectors on that side are plugged.
Of course, I don't believe EITHER is the case - I'm not convinced that what you THINK you are seeing is what you are really seeing. BUT, you are there and I am not.
But look at the electrical diagram, what else could it be?
on
on
1 Post
Well, I have installed three CPS, still will not start. Checked wiring from connector to the top of wiring harness in large fuse box. Anyone have any good ideas on getting it to run again Also changed Camshaft P S, still no change.
Hope someone in Houston could lend a hand to help me get this on the road.
HELP!!!!!!!
David Tinker
281-635-0869
HELP!!!!!!!
David Tinker
281-635-0869
HELP!!!!!!!
David Tinker
281-635-0869
HELP!!!!!!!
David Tinker
281-635-0869
https://www.needswings.com/contactus
HELP!!!!!!!
David Tinker
281-635-0869
HELP!!!!!!!
David Tinker
281-635-0869
Have any codes been set, what you state about changing the CPS does not help us.
HELP!!!!!!!
David Tinker
281-635-0869
HELP!!!!!!!
David Tinker
281-635-0869
New Crossfire owner here. Was looking into obtaining a Crankshaft Position Sensor mostly as a back-up and found these on Amazon. Anyone used these various brands?
https://www.amazon.com/gp/search/ref...qid=1524397526
Some of those are original Bosch for our car. forget the first one first one it is the correct part but to pricey.the third is a Bosch part #3 xxx xxx 28/28.
Hi all,
Removed the CPS but it's not the same reference. The one I removed is Mercedes P/N A 003 153 27 28 and Bosch 0 261 210 171 whereas the recommended one (the one I ordered) is 0 261 210 170 (on the left):
My Xfire is coming from Spain (MY2007). Maybe that's the explanation.
BTW, the sensor was very difficult to extract, but I couldn't insert the new one. Too difficult because it seems the hole is too small. Is it OK to add some oil to ease part insertion? Otherwise I can't imagine how to push the sensor into the hole, due to lack of space.
Any help welcomed !
Any help welcomed !
Thanks a lot for your answer.
I noticed also there're 3 plastic "flanges" probably to make the sensor stick in the hole, and maybe that's why it's so difficult. Maybe I can use a nail file to loose it a little, at least to ease the insertion in the hole.
But first I'll try to clean up to hole.
Just for those who might face the same problem, here're the tools I used:
Just an advice: put a rag beneath to catch the bolt, just in case and have a magnet around.
It saved my day
Now, I have to check if it solved my issues: erratic idle from 600 to 2200 still or at low speed.
It saved my day
on
As you unscrew the bolt, hold on to the sensor and pull - pull the sensor out with the bolt still in the mounting hole on the sensor and carefully extract both at the same time.
Worked for me and I did it all with a ratchet, extension and socket.
