Evosport Power Package
Old 01-03-2007 | 11:48 PM
SRT6_Roadster's Avatar
Default Re: Evosport Power Package
Contact any Kleeman dealer or Kleemann USA. You can purchase the cams from them. I am not sure if RENNtech still sells the cams.
You can also contact Turner Motorsports (as per HDDP's posts) & purchase the Schrick cams for cheaper than the Kleemann stuff.
Old 01-03-2007 | 11:55 PM
HDDP's Avatar
Originally Posted by SRT6_Roadster
Contact any Kleemann dealer or Kleeman USA. You can purchase the cams from them. I am not sure if RENNtech still sells the cams.
If you're serious about buying the Schrick Cams, I can get them for $1,400... I just don't want to get a bunch of empty inquiries, just serious purchase orders...
Old 01-21-2007 | 10:43 PM
Sidez's Avatar
I can find some hard numbers (sort of). Unfortunately they are not for the cams in and of themselves nor was it on a stock car but here you go:
Before today:
After Kleemann ECU/Pulley
Max HP _____ Max Torque
311.27 _____ 311.64
New performance mods added as of today:
SL55 Y-Pipe
Kleemann Cams
Kleemann LSD <--- Not sure this makes a difference.
Temp outside was about 73 degrees.
Max HP ______ Max Torque
360.0 _______ 349.8
http://www.benzworld.org/forums/r170...light=Tungster
i know i am bringing up an old thread, but all he gained was 20 rwhp from pulley and ecu? how come so little? it just seams like something is wrong...
Old 01-22-2007 | 12:44 PM
Steve Hellums's Avatar
Sidez, I'm told that the AMG engine is tuned so close to it's maximum safe output that there is just not that much more h.p. to get out of them and still have a safe tune. I'm also told that if you could improve the intercooler of the supercharger you could get a little more, but with the way the intercooler is designed on these superchargers you'll cause them to heat up if you try to push it to far.
Old 01-22-2007 | 02:37 PM
Maxwell's Avatar
Wow, 20 hp from just a pulley and ecu is really a lot of power gained. You have to remember that this is a large belt driven S/C which is sucking more power from the engine every time you upgrade the power output.
I think if you install the SLK32 cams you will gain another 15-25 hp, since they are designed to function better with the AMG blower.
Old 01-22-2007 | 05:02 PM
Sidez's Avatar
what i am trying to say is 20 horsepower from ecu and pullets and 49 from camshafts and sl55 intake?
Old 01-22-2007 | 05:29 PM
Maxwell's Avatar
you're making 49 hp from the sl55 intake and better cams? that could be true.
04-28-2016 03:04 AM
MiamiTVR
Other Vehicles
11-11-2015 01:36 AM
atdavis2
09-21-2015 02:25 PM
Valk
09-17-2015 12:43 PM
04Fire
09-15-2015 08:40 PM
