Wipers won't stop
Wipers won't stop
Hello to the forum. My name is Bourbonton, new to all this, not used forums so forgive any stupid questions.
I have a Crossfire 2005 Roadster, had it a couple of days and the wipers will not stop, unless ignition off, are they controlled by the body control module or is there an independant relay, if so where can I find it?. I have a digital full service manual but doesn't seem to show a relay but I see they are available for sale , confused
Grateful for all and any replies
Bourbonton
Bourbonton
Re: Wipers won't stop
The 15A fuse 32 in the underhood accy fuseblock should get them to shut down. Page 1786 is the diagram.
The 30A fuse 20 could be just the motor or the motor and other stuff, not sure.
The fix? Hmm... A multimeter testing the multifunction switch to see if it is bad.
Could the motor park switch be bad? Resulting in a no park sense condition.
A multi-meter could test the park switch. C2 pin 40 of the Body Control Module would go to 12V every cycle of the wipers. If so, not the motor. I am suspecting the multifunction switch since that has been an issue way more often. C3 pin 63 & 65.
Right hand drive may have a slightly different pin number, gotta look for sure.
o55ie18
10-05-2015 06:50 PM
