re-did steering wheel
on
I have looked for ways to clean or rejuvenate the Alabaster steering wheel, and I finally found a way.
I was looking for Dye or shoe polish to match but couldn't find one. I found a website where they were changing the color of cheap leather purses. They gave instructions, and it sounded like it would work on my project. Surprisingly it takes acrylic latex paint (there is a leather paint, but it is the same thing). The hard part is matching the color. In the craft section at Walmart they have small bottles of latex paint. Get 1 yellow and 1 brown and 1 white. (50 cents each) I used about half of the white to start, and a little brown and a very little yellow. You will have to adjust back and forth until the color matches, but I got it exactly after about 3 tries. Mask off the center part. (I just painted the outer part).
I cleaned the wheel good, masked it, painted the first and second coats with a watered down (1 to 1 mixture of paint to water) Wait about 15 to 20 min. between coats (Do not let it dry completely). Then paint the third coat with undiluted paint. I was surprised that it turned out so well, it looks like a new wheel. You can still see the texture of the leather.
Here is a "before and after" picture.
Re: re-did steering wheel
You could say it turned out wheelly well.
Truly an amazing DIY task and very creative. I was perusing the Colorbond website for leather dyeing and they actually have a video about using their product to restore a steering wheel & associated trim pieces to "factory new" appearance. I couldn't help but think about owners with the two-tone Dark Slate Gray & Cool Vanilla interiors that have the "white" steering wheel. Seems like using the Dark Slate Gray Colorbond product to dye that steering wheel (including airbag) would be an interesting DIY project. (Note: Masking the airbag could be a major DIY project in & by itself.) During 2008 model release, Chrysler actually delivered the two-tone Dark Gray/Vanilla interiors with a Dark Gray steering wheel. Actually looked pretty good that way.
Once again, a very good restoration job! Congratulations!
on
The result is truly amazing, I am going to give it a try!
Stupid question: does the exterior color determines the interior color? Mine is darker than yours (2005 Graphite Roadster).
Should I use the same color combination with more brown then?
on
Re: what is the name of the color of this interior?
what is the official name and/or code of the light beige color of this interior? see pics in original post of this thread. is it cool vanilla?
I need to paint my steering wheel its same as in this thread.
