Universal central locking
Old 08-11-2016, 10:37 AM
kamilspider's Avatar
Default Universal central locking
Hello everybody.
My oryginal remote control is broken.
I bought universal remote control (something like this: https://alltronix.pl/userdata/gfx/38473477.jpg) without alarm.
I connect it to white/green cable behind switch on central console.
All conections are OK and everything almost work...
Now normaly I can close and open doors but only about 30s after removing the key from the ignition.
When I remove key from the ignition, switch on central console work ok only about 30s, later it not work and I must opened doors by key (not by remote control).
I check fuses... When I remove fuse nr 7 (motion sensor, central control unit) control doors by remote control work everytime great. But this fuse is necessary and I can't remove it for ever.
I not have any ideas for this problem, I lost 6h and still not working correct.
Maybe I can change something by Star Diagnosis?
What I can do for solve this problem?
P.S. Sorry but my english is not the beast.
Old 08-12-2016, 11:03 PM
Default Re: Universal central locking
I believe that the switch you are using is disabled 30 seconds after removing the key as a theft prevention measure.
I think the only way to do this is to wire to pins 8 and 9 of C1 on the SKREEM. Those are the wires from the driver's door key switch and they work all of the time.
Old 08-14-2016, 11:32 AM
Thank you for reply.
Where I find pins 8 and 9? Do you know colors wires?
What is it C1 and SKREEM?
I strip left doors but to the lock is only 1 yelow pipe with underpresure, not any wires.
Maybe I can do make something with door limit switch? (on/off roof light).
Or maybe it's better idea for connect it directly to vaccum pump? But I afraid that damage pump.
Old 08-15-2016, 09:03 AM
Real busy at work, I will answer this later today.
(I got your message just now...)
Old 08-15-2016, 11:49 AM
Ok.
I check that if I give power to door switch they open every time but I still have only 30s for close doors...
Old 08-15-2016, 12:21 PM
The SKREEM is behind the instrument panel. See below:
Old 08-15-2016, 12:31 PM
See post 42 for help on gettting to the SKREEM, it is behind the instrument panel.
https://www.crossfireforum.org/forum...ictures-3.html
Old 08-15-2016, 02:41 PM
Pizzaguy many thanx.
I want fix it in this week and I let you know!
Old 08-15-2016, 03:07 PM
Not too sure what this means but the OP is in Poland, that's in Europe last time I looked
Save
Old 08-15-2016, 03:14 PM
Ajajaj Poland is in Europe and car was made in Germany.
I must check this in my car.
Old 08-15-2016, 06:02 PM
Dave (100/80) and kamilspider:
I THINK that the car will still have that but on the other door. How else could you unlock with the key and not set off the alarm???
Old 08-15-2016, 08:03 PM
If it was on the other door it would not need to mention anything.
Old 08-16-2016, 01:40 AM
I bought this car with only 1 key with broken remote.
Normaly I can open/close doors only by key. I not have alarm or it is off.
Old 08-16-2016, 02:51 PM
Pizzaguy unfortunately your idea not works in my car. When I give -12V to black or blue wire 8, 9 nothing change.
But I solved problem myself
I give -12V to lock switch on the control panel (white/green wire) and second -12V to door switch (http://i.imged.pl/mercedes-w202-czuj...4462222779.jpg), this door switch is connected witch relay. (before was -12V and -12V +200ohm to white/green wire).
I not know what was a problem before but now everything works grate. I can open/close doors when I want
I'm very happy, this was beautiful day!
Visionarix
08-02-2016 01:08 PM
Zoodust
07-28-2016 12:56 PM
mark anthony
07-21-2016 10:51 AM
Zoodust
07-14-2016 10:19 PM
Raindem
07-04-2016 02:00 PM
Quick Reply: Universal central locking
