Racing The place to talk about autocrossing, road and drag racing.
Went to OSW tonight
Old 01-17-2016 | 02:36 AM
chuK_138's Avatar
Default Went to OSW tonight
Weather was good today and I had just installed my manifolds that had been sitting around for over a year, so I decided to coax Kim to going to go to the track. ThumperSRT (Chuck) helped with the install but couldn't make it out unfortunately. Times ranged from mid to lower 12s, with a best tonight of 12.281 @ 113. Trap speeds weren't great and the track had been repaved recently leaving some nasty ruts up top. So bad a GTO ate the wall once the temps got below 65. I'll see if I can upload videos through my phone or update the thread and add them from my PC.
Old 01-17-2016 | 11:19 AM
velociabstract's Avatar
Default Re: Went to OSW tonight
N/W manifolds leaned out my AFR's enough to be worried. That doesn't explain the 113 though. But again, 113 fits perfectly with 12.281 based on my cars past runs. Perhaps the ECU is adapting or the DA wasn't as good as the 114.90 night. Either way, I hope you had fun and I'd love to see the vids! If this was on street tires I tip my hat to you.
Les
Old 01-17-2016 | 11:26 AM
chuK_138's Avatar
Yes Les, on street tires always. I really need to invest in a wideband setup soon so I can log my AFRs. I haven't had a chance to contact EC about a retune for the change and the ECU didn't get much time to learn. All in all, I guess should be happy with those times.
Old 01-17-2016 | 11:39 AM
You don't loose power running lean ….. unless ultra mega lean or until you blow up. My memory could be off but I believe the N/W manifolds leaned out my AFR's by .5. E/C is normally conservative with their tunes so your most likely still OK, especially if you use 93 octane. But yes, get E/C in the loop just in case. My best on street tires was 12.75. I blame it on my flat floppy numb feet.
Les
Old 01-17-2016 | 12:28 PM
good runs chuk I am in Melbourne this week arrived ,Friday, unfortunately without the crossfire,,,OH there are two F S here in Melbourne one black roadster around $9000, and a coupe graphite for $4000.. I will be heading south Friday or Sunday car is at J S Benz getting ready for a show. and drags. going back to 180 pulley and adding a second afr reading on the other exhaust pipe. and a few other things. jim
Old 01-17-2016 | 10:21 PM
chuK_138's Avatar
Old 01-17-2016 | 10:23 PM
chuK_138's Avatar
Old 01-18-2016 | 12:52 PM
ichon's Avatar
Nice vids brah. love the commentary by Kim...
JimmyJames
02-16-2016 09:15 AM
Dementors
02-04-2016 06:31 PM
Blackktieguy
01-11-2016 06:58 PM
crossfiremaniac
01-11-2016 11:51 AM
Franc Rauscher
12-19-2015 12:32 PM
