2004 speaker cover needed, dome light fuse and headlight question
Hi all,
Just got a used 2004 and still working through the issues. I have been reading this site tonight and it's already answered several questions.
I'm still in need of 3 things:
1) Drivers side door speaker cover... does anyone have one for sale or can tell me where to get one?
2) The dome light does not work so I'll start with the fuse. Trouble is, from the owners manual, cannot tell which fuse number it is, can anyone help?
3) Saw an article here about cleaning the inside headlights with methanol. Question is, how do you access the inside of the bulb?
Thanks
Bamarant from Northwest NJ
Thanks
Re: 2004 speaker cover needed, dome light fuse and headlight question
Hi all,
Thanks
Thanks
2) #9 fuse under the hood (roof light) but it may be the bulb has blown or loose. By loose I mean a bent or sloppy contact, a known weakness.
3) Take the headlight unit off the car and pour it in where the marker bulb was.
1) MrMopar sells spares from wrecked cars.
2) #9 fuse under the hood (roof light) but it may be the bulb has blown or loose. By loose I mean a bent or sloppy contact, a known weakness. (Is the slider switch in the right position?
https://www.crossfireforum.org/forum...-assembly.html
Here ya' go.
It absolutely MUST be the purest Methanol you can find for a perfect job. Any contaminants will be water, and since it evaporates so much more slowly, you will see where it does.
Other than that, this works great!
Here ya' go.
mhajek18
110
09-06-2019 01:04 PM
rayth
41
07-31-2019 04:02 PM
WindRestrictor
06-01-2015 02:31 PM
Andreanna
12-02-2003 10:22 AM
