Seat back leather removal??
Old 01-01-2011 | 09:43 PM
LantanaTX's Avatar
Default Seat back leather removal??
Anyone ever pull the leather cover off of their seats? I have a new leather cover to replace my aging one and am not sure how to pull the old learher cover off. Thanks for any help
Old 01-01-2011 | 10:09 PM
SNAKEWOLF's Avatar
Default Re: Seat back leather removal??
CrossfireForum.org See Seat Heater Triump
Old 01-01-2011 | 11:29 PM
32krazy!'s Avatar
try this thread by buggin. he did his and has some good pics here
Inexpensive seat heater replacements - Benzworld.org - Mercedes-Benz Discussion Forum
Old 01-02-2011 | 01:47 AM
LantanaTX's Avatar
Thank you!
Old 01-02-2011 | 10:32 AM
LantanaTX's Avatar
The instructions seem to be for repairing the seat heater. I am just trying to replace the drivers side seat back leather. Do I need to take the whole seat out to do that? I am not doing anything to the seat bottom right now.
Old 01-03-2011 | 04:49 PM
red_three's Avatar
Hi,
I had mine apart during a warranty repair that made the problem worse, before finally fixing it (long story). From what I recall the cover fits over the frame like a sock. The bottom part pushes into a slot and the sides clip into the plastic cover on the rear of the frame (hopefully there's a picture attached). Once un-clipped if you place your hand/arm up inside the seat back (between the frame and foam, not foam and cover) you should feel that you can pull it forward an inch or two and find the connector for the heating element. Disconnect that and the foam and cover can then be pulled up and off together over the top of the seat.
The foam and cover are joined together by a dozen or more small plastic clips.
One end of each clip passes through a loop of stitching on the cover and the other end onto a metal rod molded into the foam. Be extra careful trying to separate the clips as there is very little room to get your fingers in - maybe theres a tool that does this? I only mentioned caution as the dealer had ripped part of this rod out of the foam during the repair. The cover would not sit properly after that and the sides of the cover wouldn't stay because the tension from the rod in the foam holds it in.
Hope that helps
axnguyen
07-21-2015 12:41 PM
XFIRED-TX
07-17-2015 12:56 PM
XFIRED-TX
07-14-2015 11:48 PM
Rusty475
07-13-2015 11:03 AM
tom2112
07-08-2015 09:13 PM
