Heated Seat Aftermarket Repair
Randy, you look like the most recent person to do this repair. Can you share your steps and exactly what and where you ordered your parts from. How hard was it? any chane you could do a write up? Thanks
Jeff
Nevermind. I was going to try this myself, but found a local shop to do an aftermarket repair for $250, will post results. After reading all the posts related to the heated seat failures and repair failures, I'm going to go with an aftermarket CF heated seat kit. Obviously there is a design flaw in the current heated seats. Surprised there isn't a recall at this point. The other xf we went to look at before we got FP's also had the driver seat not working. Would love to see a poll of how many here had failures.
Jeff
Re: Heated Seat Aftermarket Repair
Randy any chance of giving me the make, model., part no and supplier of your aftermarket heated seat kit. I'm in adelaide south australia and my local dealer wants aroung $600 to supply and fit. It will also be 6 weeks. This will be my 3rd replacement . I need a website/email or some way of ordering.
Thanks, Deane
Thanks, Deane
quote from a local dealer was $1200 to repair driver seat heat. Can you give me the info on where you purchases the seat pads?
Thanks Randy
Which pads did you buy from Heatmyseats?
Are they in Canada or did you have import fees?
robertweckman@rogers.com
Randyg did you order the H3 seat heater recommended by heat my seats? i was wondering about the carbon one if those might be a little harder than the H3... also about how many hours labor do you suppose it took to do one seat? i will be having my car fix it man do this task and am wondering about how much this will cost me.
let me know thanks bunches for blazing the trail!
Spensley... I need to get my seats heating again as winter is heading our way. I assume your seats are still working well and was wondering if you could supply the vendor/item #? you had to cut off the after market ****/wire assembly and wire directly to the current xfire **** wiring and lay the heating pads between the leather and cushion?
Thanks in advance for your help with this...
usprb1976
04-04-2024 04:57 PM
Blackktieguy
21
10-26-2015 12:32 AM
atdavis2
09-21-2015 01:25 PM
steps
09-19-2015 10:43 PM
