Removal of Access door Cargo Area
OK I admit it I am mechanically inept! Can someone explain how to get the cardboard like access door open in the cargo bay. I need to change the cargo bay bulb and I believe I have to access it through there. I have tried to pull up on the notch at the base of the door with no luck. There does not appear to be a tab release there. I am afraid if I pull too hard I will crease the door panel. Please help!!!
Re: Removal of Access door Cargo Area
they are just slid in place and wedged in between plastic upper clips (shown below)...
slip your hand in the bottom gap & pull... they will pop out... and they will bend back into place if warped.
Thank you! I got it. My design was a bit different. There were two large tabs on the bottom and no tabs on top. The bottom tabs had to be bent enough to clear the lip. Now, how does the cargo light come out. Do I disconnect the electrical connector (which I can feel with my hand) and try to push the light housing out through the front or do I just try to reach around and remove the bulb?
rocketrage
10-07-2015 05:00 PM
RED DOG
07-21-2015 07:58 AM
