Putting on a supercharger
Re: Putting on a supercharger
The NA engine is not built for boost, compression ratio is too high and internals not strong enough.
It’s a different engine and you need the ECU mapped to work with the supercharger.
it would be less expensive to purchase an SRT and work on refreshing it.
If you’re set on the swap, buy a damaged donor. It’s less expensive and easier than having to scour the web for all of the required parts.
or see cheapest V8 swap currently underway on the forum.
He appears to have the v8 swap dialed in for under 4K
dontlovedodge
03-08-2012 06:42 PM
rcompart
47
12-26-2010 07:36 PM
