Headlight Cluster
Re: Headlight Cluster
This method will remove the condensation and any water marks. You have to remove the headlight from the car. With the lens of the headlight laying flat down on a table poor a small amount of 99% methanol into the corner marker light hole. Swish it around the lens, and then poor it back out of the marker light hole. Do this a couple of times. WARNING - You must let the headlight thoroughly dry out before putting the headlight back in the car and turning it back on.
You can buy the methanol from Amazon:
Chriscr0ss
01-23-2016 06:04 PM
