Right brake light not working
I replaced the bulb with the excact replacement. Still no right brake light. What else should i look at? The socket is like new and there is no rust or corrosion issue around the socket. The taillight is within the same bulb and it works. What else is there to look for to fix this? 2005 Roadster with 40k miles
Thanks
Thanks
on
Re: Right brake light not working
You may have used the wrong bulb, or the bulb you bought is defective (yes, it happens). You can screw around and waste time all you want to, or, you can take the easy way out:
Trade bulbs between left and right. Does the problem follow the bulb or stay with the socket? This way, you know if it's the bulb or not. If it's not the bulb, it's gotta be the socket.
Moved to appropriate forum.
Just1Starr
07-17-2018 11:59 PM
rochelle
09-20-2016 07:40 AM
