Found this in cowl area! What is it?
Old 03-17-2020, 04:46 PM
Question Found this in cowl area! What is it?
... Deleted ...
Old 03-17-2020, 05:19 PM
Default Re: Found this in cowl area! What is it?
My guess is that it stops debris or water getting around the drain outlet. It’s position being between the fender and firewall. Or not.
Old 03-17-2020, 06:05 PM
... Deleted ...
Old 03-17-2020, 06:25 PM
Iamfink2's Avatar
I would also like to know what that is I found mine inside the cowl area about 6 or 7 years ago and could never figure out where it belongs. I still have it in case somebody knows where it goes.
Old 03-17-2020, 07:19 PM
Sussudio's Avatar
Same here. I’ve had that piece in my trunk forever. Have no idea where it came from either.
Old 03-18-2020, 01:16 PM
It sounds like whoever was assembling out cars didn't know what to do with it either so just left it in there. probably was included in an assembly kit.
Old 05-19-2020, 07:33 PM
It is an interior piece that covers a small area behind the seat on the vertical wall where the speaker is. If you locate the speaker (lets use the passenger side speaker behind seat), look up to let corner of where carpet on vertical wall meet the plastic, it covers the "corner" that is missing. I just found that piece as Im replacing the back speakers!
Old 05-20-2020, 03:12 AM
Sussudio's Avatar
I’m curious if this piece is not used for other areas of the car as well? Mine was in the trunk and have no idea how it got there. I’ve taken all the panels apart before to get to the door locking pump. So it could’ve been when I was doing that. PITA by the way. I’m going to check now where you said you found it and see if I have it missing from either side. No biggie, just curiosity now.
Old 05-20-2020, 09:38 AM
I found this 'foam' thing in the cowl area today while re-installing the chirping siren I replaced the 4.8v single battery into. This part was on the passenger side under the hood hinge. It is light enough to have come from either side. I was surprised it had not fallen into the squirrel fan for the Heat/AC since that is quite a large opening. I found it while making sure all 4 drains were clear (which they were). It is VERY soft foam, and it has a few letters and a MB logo on it. Any one know where it came from? The cowl will not be reinstalled if it is for a vibration abatement or needed for a particular specific reason. Thanks for input if you know what it is! .
It probably goes in hole somewhere to keep noise from coming into the cabin, there is a piece of foam similar to that behind the passenger seat where wires pass into the trunk area. I never could get it to fit as well as it did originally.☹️
Old 05-20-2020, 01:14 PM
... Deleted ...
Old 07-14-2020, 04:13 PM
VintageBikesUSA's Avatar
I know this is a few months old but I found that in my cowl area when I was cleaning it out the other day. . .did not see where it went back.
williamfrog (09-05-2021)
Old 07-14-2020, 09:24 PM
... Deleted ...
Old 08-04-2020, 09:20 PM
Replaced my siren and found this piece as well, it’s a mystery. 🤷‍♂️
Old 10-17-2020, 11:15 PM
One of the reasons why I bought another XF . .so I can see if I have these the the cowl of this car to!
Old 10-18-2020, 12:08 AM
There are other areas that have parts like this, they seal up gaps where wires pass through.
One place that has one is behind the passenger seat under the carpet and door trim, I took it out when I passed wires to and from the hatch area.
I guess it is to reduce sounds and possibly hinder air flow.
Old 10-18-2020, 09:47 AM
RED DOG's Avatar
I found out where that foam piece should go when I removed the cowl cover to clean out the gutter drains and replace the siren on the SRT6 I am currently refurbishing. I will get a photo in the next few days as unfortunately I need to remove the cowl cover again. Until I can post a photo, The little tip (shown at the top of the OP's photo) pushes under the right lower lip of the windshield glass with the rest of the foam piece sticking out to support the rubber "drain grate fingers" on the cowl cover.
Old 10-18-2020, 10:26 AM
Interesting, please post a photo.
Old 10-18-2020, 01:33 PM
Toolman's Avatar
Yes, please post a photo. You extra effort removing the cowl again is appreciated.
Old 10-18-2020, 03:20 PM
... Deleted ...
Old 10-18-2020, 06:53 PM
I can see nothing under the fingers on my car, and I cannot see why those fingers need supporting. Or is the foam piece hidden from sight?
I am quite baffled by these parts, similar parts are baffles elsewhere.
Quick Reply: Found this in cowl area! What is it?
